Vanos M50 to 3.0L (Stu?)
  • Jean
    • 18228
    I did a search and understand that it would take 3.0L m3 pistons and rods (s50/s52 rods are the same) + 3.0L crank. If a 3.2L crank is used then piston work is needed correct?
    What other BMW pistons/rods/cranks can I use to accomplish this as well?
    Thanks.
    "Stock C/R on all US M/S50's is 10.5:1, with the exception of the Non-VANOS 2.5 which is 10:1.
    Both Alex and I had out motors built (Thanks Dad!) from '91 525i blocks, and 3.0 M3 pistons which were at our availability. Alex sprung for the 3.2 crank, so decided to go with a .040 overbore on the 525 block to fit the 3.0 pistons and 3.2 crank. As you can picture, the 3.0 pistons need to be machined down due to the stroke difference, but 86x89.6 was achieved with high-compression. It's a pretty straight-forward recipe for a lot of torque and HP--though not quite the CC's of a standard 3.2 bottomend (I believe they use 86.4 on the pistons, marginal difference).
    The only 24v E30's I've driven have been mine and his, my dads 2.9, and a friends 2.5. I can tell you that the 3.2 crank makes a MASSIVE difference in the 2000-4000 range. While my 86x86 3.0 pulls well and makes plenty of torque, it doesn't really start to haul ass until 4000revs.
    Any nicely setup M/S50 will pull well at high revs, but that is only used when you're racing somebody, or are on-track. If you plan to use your car for a lot of around-town driving, a 3.2 crank is a really good way to go. (PM Jason89i for more insight)
    I can't say whether an 86.4x89.6 will make more power than a high c/r 86x89.6, but either setup with the right bolt-ons will make more power/tq than our brakes need!"
  • Stu
    • 4083
    You can use a 3.0L crank, standard 135mm rods from the 3.0L, and the 86mm pistons from the 3.0L. You'll need to have the block bored to 86mm (obviously).
    I've heard of people boring VANOS 325 blocks (93-95) to 86mm with no reliability problems, but it might be a good idea to pick up an early 91/92 block if you can get your hands on one.
    I'll post more later on but I'm heading out the door at the moment
    • PiercedE30
      • Apr 2005
      • 4220
      OR you can get an S52 crank and M54B30 rods and pistons (or just an M54B30 rotating assembly). That makes 3.0L with 84mm bore.
      My 2.9L Build!
      • CorvallisBMW
        Long Schlong Longhammer
        • 13039
        nice and torquey too with the longer stroke!
        • SpecM
          • Oct 2005
          • 4531
          -What CR is the 86x89.6?
          1989 cirrisblau-metallic 325i
          • 318isbmw
            • Nov 2005
            • 2841
            Depends on deck height and piston tops...
            And headgasket
            • PiercedE30
              • Apr 2005
              • 4220
              And chamber CC (if milled head).
              My 2.9L Build!
              • Jean
                • 18228
                So here is another option I see, sounds like no piston or block work needed, correct?
                Originally posted by 01djb
                I have a M50 3.0 stroker rotating assembly It's a forged s52 crankshaft Also same crankshaft used in m54 3.0 (e46) m54 3.0 pistons,m54 rods.These parts have 80k miles on them ...this will drop right in to m50 block. same bore size(84 mm) no machining needed ...All you need is a good low mileage m50 block, and you are set...
                Thanks,
                Boris S.
                Thanks Stu! Blunty told me you would know this :) Why the NV block though?
                S50 crank/rods/pistons are probably easier and cheaper to get yes?
                Does the s50 or m54b30 crank drop right in in place of the m50 crank and all of stock m50 hardware work the same?
                • 318isbmw
                  • Nov 2005
                  • 2841
                  Yes they drop in easily, no work needed. Lately I've seen a few people selling s52 crank and m54 rods and pistons for sale for around 550. Was one last month, and seen a few on bimmerforums also.
                  • Jean
                    • 18228
                    What are they upgrading to?
                    • atomic
                      • Jun 2007
                      • 5691
                      Jean I am glad to see you with these threads going. I am just behind you with a s52 swap that is going to be gone through before hand...
                      Just a thought and not sure if you can use them, but I should be having some s52 cams FS in the near future.
                      • Danny
                        • 14217
                        Uh oh
                        • KangamangusDriver
                          • Aug 2005
                          • 1870
                          The NV block has thicker cylinder walls, stronger, better to bore.
                          • Jean
                            • 18228
                            Awesome, what are your plans with yours, going with Schrick cams? PM me regarding your cams please
                            Thanks!
                            • Jean
                              • 18228
                              I see! Well, it's too late as I wanted a vanos motor so I gotta do with what I got. What seems to be the maximum safe bore on the vanos blocks? It will remain NA, but will be used on the track all of it's future life.
