Vanos M50 to 3.0L (Stu?)
My 2.9L Build!
Originally posted by Ernest HemingwayThere are only three sports: bullfighting, motor racing, and mountaineering; all the rest are merely games.Comment
What CR and Cams should I shoot for?
Thanks!Mtech1 v8 build thread - https://www.r3vlimited.com/board/sho...d.php?t=413205
OEM v8 manual chip or dme - https://www.r3vlimited.com/board/sho....php?p=4938827Comment
www.gutenparts.com
As time went on, the factory developed the car each year, making it faster, more comfortable, and capable of handling at higher speeds.
You don’t want this. You want the trickiest, most dangerous, oldest model you can find. Only then can you prove to the world that you’re a man.Comment
My 2.9L Build!
And to add another thread with good info - http://www.r3vlimited.com/board/show...t=m50+s50+camsMtech1 v8 build thread - https://www.r3vlimited.com/board/sho...d.php?t=413205
Who said anything about shaving anything?My 2.9L Build!
My 2.9L Build!
Yea. Set everything the way it should be and the slack in the chain will be taken up by the tensioner. Since the main timing chain doesn't directly drive both cams (separate chain between the cams) it shouldn't have any effect, unless you shave the block to the point where the are mere thousandths between the deck and the top of the coolant channels (literally have to take off close to 3/8 of an inch) and it is close to becoming an "open deck" block. But at that point you are already screwed. Since the valve seats are already fairly close to the surface of the head, at the edge of the combustion chamber, there really isn't that much you can take off of it to make a radical change in timing.My 2.9L Build!
