quick ABS wiring question and verify pin to pin for 318is...
  • jakeb
    • 1909
    So I think I have all the wiring figured out. Just need to get the ABS wiring correct. Do I have to splice into the main relay power? I am putting this is a 318is and pin 6 of the c101 comes off the ignition switch with a fuse. From the ETM it shows that the ABS power is just powering a relay that turns the ABS pump on. It would be really easy to just connect pin 6 and pin 20 on the c101 rather than tapping into the main relay power wire.
    Here is the ABS diagram
    and the pin to pin for the 318is to m50. Is this right? I went through the 318is side and everything is right. Other than a couple of the labels, pins 6 and 7
    TIA
    www.classicdaily.net
    1970 m42 swapped 2002
    1985 LS1/T56 Swapped e28 (557e)
    www.blunttech.com - For all your parts needs
    Follow me on Instagram for constant build updates @classicdaily
    https://www.facebook.com/ClassicDailyLLC
  • 318isbmw
    • Nov 2005
    • 2843
    It all depends on year of the harnesses that your going from and to. That worked for me like I mentioned to you, but honestly theres no way of telling w/o pullin out a diagram of all the electronics and tracing pin to pin for your exact year.
    • Mike B.
      • Jan 2006
      • 987
      If pin 6 (318is) provides 12v (switched/crank/run) on the chassis side of the connector, then, yes you should be able to loop a wire in the C101 and connect it to pin 20 (318is).
      • jakeb
        • 1909
        yes it does have power at pin 6. Does the ABS pull much power. From the ETM it is just powering a relay so it shouldn't be all that much power
        • FredK
          • 14761
          The ETM indicates it's a .75mm wire, so it's not pulling much current.
          Pin 6 is hot in start and run.
