NO start
  • gregslow318i
    • Sep 2007
    • 1918
    lol same hear just fownd another dme for $50 on cl but I know mine is good I just can figer it out
    looking for a e30m50 swap harness adapter pm me $150 shipped
    email nitroman12@gmail.com
    • 416stroker
      • May 2008
      • 2448
      Would it not start if i didnt have coolant in. Is there any safties like that built in the dme.
      84 318I Delphin RIP
      87 325IS delphin 24v Sold
      89 325 Alpineweiss
      • gregslow318i
        • Sep 2007
        • 1918
        does any one know if the cps gets voltage on start up? and how much and what pin?
        • 416stroker
          • May 2008
          • 2448
          Ok I think my DME is bad I have power in all the correct pins at the dme. Is there anything else besides the cps that could keep my car from starting on a 92 nonvanos engine.
          84 318I Delphin RIP
          89 325 Alpineweiss
          • 416stroker
            • May 2008
            • 2448
            found out the problem today my computer is toast.A lot of hot spots in the bored an now its fucked. So if any one has a 402 dme laying around hit me up
            84 318I Delphin RIP
            89 325 Alpineweiss
            • gregslow318i
              • Sep 2007
              • 1918
              hmm that does not help me why did it go bad or did some one sell you a bad one? also I have a dme out of a 525i non vaose car same as the 402 but a different chip I think I may have a bad harness
              • 416stroker
                • May 2008
                • 2448
                ya the guy i got all my stuff from told me it was good be he didnt know for sure it was in his shop for a while. You sure you got all of your grounds right?
                84 318I Delphin RIP
                89 325 Alpineweiss
                • gregslow318i
                  • Sep 2007
                  • 1918
                  yeah all my grounds are good it is like the dme is not seeing the crank signal or something that is not letting it fire
                  • gregslow318i
                    • Sep 2007
                    • 1918
                    so a little update
                    I have swaped a know running m50 nv e36 harness in and I am have the same issue
                    but I have discover something
                    if I have the cam and crank sensors plugs swaped the car will back fire and spuder but if the are installed correctly it will sill on start via no spark and the the fuel injectors and event the pump will not turn on? so I am kinda at a loss
                    • gregslow318i
                      • Sep 2007
                      • 1918
                      well another update turns out when I have them swapped backwards and it back fires think that in fact they are in the right position and that the cam sensor is making it back fire
                      does anyone know what the symptoms of a bad cam sensor are ?
