Help! I have been overheating at stoplights lately. I have an bmwcca prepped IP S50 motor(schricks, hfm, 21#inj, fan delete, aa header etc) in my 91 E30. I put in the Mcoupe S54 radiator w/ 3 rows when I swapped. When I am on the road, my water temp is usually @ 210 and my oil temp is ~200. I had a/c put on my swap and I have been steadily upgrading pusher fans to help compensate for the added heat. So far nothing has worked. Tonight I put on a 3000cfm fan and it still wants to go over 250 if left idling. Any ideas? It already has the lower temp switch and thermostat in it. I will try to tape up around the radiator and condensor so that it is more efficient. Anything else I can do?
Help! overheating in Stop-n-go traffic.
