Fuel Consumption Report: 3.0 M50/318is
  • Stu
    • 4083
    I decided to keep track of fuel consumption for a typical week of driving for my E30 to see how economical it was during a work-week commute. I kept the rules pretty simple: 5-days of commuting to work and occasionally small errands after work. I started Monday morning before work with a full tank, and filled the tank Friday night at about 8pm, after running an errand. This wasn't an attempt to hypermile and get maximum MPG out of the car; just get results from a typical week of driving. 2 of the 5 workdays I redlined 2nd/3rd gear on an on-ramp coming home from work.
    The car is a '91 318is, weighs 2620# (w/o driver), and has a 3.0L stroked M50 with no catalytic converter, euro MAF, raised compression, and an adjustable fuel pressure regulator that was set to run at 48psi (58psi at WOT). Getrag 260/3.73/slightly taller than stock tire size.
    My commute to work is 24 miles highway (70-73mph) and 3 miles of stoplight-to-stoplight traffic.
    I went out to lunch 3 of the 5 days to a deli, total of 6 miles.
    I ran errands totalling 17 miles during the week.
    In total, I drove 293 miles: Friday night I filled the tank and put in 10.3 gallons. Over 293 miles of driving, that's 28.44 MPG
    Better than expected :) Thanks to the adjustable FPR, a light car, good gearing, and an efficient engine, it gets almost the mileage it got with the M42. As a bonus, it will shake off the 996 in the next lane at the drop of a hat. :)
  • Mossman
    • Apr 2006
    • 1961
    taller than stock tire means you're getting even better mileage, but 28.44 is awesome enough.
    • e30s52
      • Oct 2007
      • 5235
      great mpg. how much Horse power does your car have?
      www.gutenparts.com
      • hoveringuy
        • Dec 2005
        • 2744
        That's really good considering all the warm-up cycles you go through. Since I know that my OBC MPG is very accurate I know that my first 5-10 miles are always horrible.
        • golde30
          • 11464
          damn, yer doubling my s50... i WISH i got that kinda mileage...
          IG: @Baye30
          • Erick
            Official R3V Drifter
            • 11169
            I know I can get 30mpg+ highway on the turbo car without the gurney flap.... the problem is that I can't keep the needle under 0psi for a whole gas tank. :p
            ..::Support FullOpp::..
            FullOpp Stickers for sale!
            Feedback Thread
            • cahomey
              • Mar 2004
              • 1201
              Maybe if your brakes weren't always grabbing...
              "It's like a koala bear crapped a rainbow in my brain."
              R.I.P. Harry Goz aka. Captain Murphy
              "My ride, My ride, she don't beg, steal, cheat, or lie,
              My ride, My ride, and our relationship is classified."
              • Stu
                • 4083
                @ Mossman, rear tires are 195/60/15, so just a touch taller than stock, not much change in effective gearing. Also should note that all 4 tires are kept at 38psi.
                @ E30S52, roughly 280
                @ GoldE30...what, Are you serious!?
                @ Erick; same here, all summer I've spent the majority of my workweek commute hauling ass and/or revving out gears, mainly to (help) subside the frustration of driving a black sweatbox in NC heat. :) I wanted to get some realistic results though, and keep track of adjustments in fuel pressure.
                @cahomey, from your PM--cams are from a '98 M3
                • SpecM
                  • Oct 2005
                  • 4531
                  -Great results, Stu, maybe now I have a logical rational for a m50 swap
                  1989 cirrisblau-metallic 325i
                  • Charlie
                    kid tested, administrator approved
                    • 6686
                    I'm seeing about 27.6 mpg highway at "aggressive" cruising speeds with a 3.73(~85 mph), so yea, it would be nice on a DD. Go with a slightly less aggressive rear end and you could probably do 29 easily.
                    -Charlie
                    Swing wild, brake later, don't apologize.
                    '89 324d, '76 02, '98 318ti, '03 Z4, '07 MCS, '07 F800s - Bonafide BMW elitist prick.
                    FYYFF
                    • Stu
                      • 4083
                      -Charlie
                      Charlie, I can't tell from your sig...is that 324e or 324d? Either way, f'n awesome.
                      • Sean
                        • 5793
                        I shoulda done a swap and not messed with the M20. I get like 24 on the highway, and maybe 20 with in town. LOL
                        That's damn good results!
                        - Sean Hayes
                        • funcrew
                          • Jun 2007
                          • 1223
                          1992 Cabrio, stock S50, ZF trans (no overdrive), 3.25LSD, 3,000+ pounds:
                          19mpg city
                          25mpg highway
                          I have a 2.93LSD I'd like to swap in to improve the cruising RPM & see if the mileage improves a bit.
                          "If the sky were to fall tomorrow, the tall would die first."
                          -Dr. Paul Forrester
                          Do I LOOK like I need a psychological evaluation???
                          • So Live
                            • 2512
                            Me too! With my 3.25LSD i get about 23mpg on average. Thats including redlining first 3 gears every day at least twice. :)
                            Great numbers though stu!
                            -Chris
