Oil level light in check panel
    • 37834
    I've got an 86 325e with an M50 Vanos in it here and need to know the correct way to disable the oil level idiot light in the overhead check panel. Thanks guys.
    Grover Beach, California
    BimmerHeads.com
  • Motorsports
    • Feb 2007
    • 2882
    Have you checked the sensor in the oil pan? Is it good?
    • EtaSport
      • 2853
      I'd dismantle the panel and remove the bulb, or LED whichever there is. That is if you are using a plate on the oil pan rather than the sensor.
      Old and improved:
      • BDSax
        Junkyard King
        • Mar 2006
        • 3594
        why not just put a jumper on the connector
        • etxxz
          • Feb 2006
          • 2085
          i'd say keep it its hella helpful.
          looking into the engine side connector with the middle, pin 3 is ground, wires 1 & 2 static and dynamic respectively. (C101 pins 2 and 10 respectively on your car)
          No more e30s for me.
          88 black BMW OBDII 332is dedicated track [sold]
          88 BMW OBDII bronzit 332is [RIP 03/08]
          91 BMW 325i [sold]
          86 Corolla 'Ae86' HB 20v trd [sold]
          http://youtube.com/watch?v=pTj7Hn9v5Rs
          • BDSax
            Junkyard King
            • Mar 2006
            • 3594
            i want it to work in my car but the sensor is bad
