You'd need a custom tune for sure to get the max power out of the motor. We can do that remotely if you have access to a good dyno.
We also build motors. Frankly, the results are better when a pro does it. Shoot me an email with your goals if you'd like a quote on a whole motor. I actually have two S50s ready to build right now.
As time went on, the factory developed the car each year, making it faster, more comfortable, and capable of handling at higher speeds.
You don’t want this. You want the trickiest, most dangerous, oldest model you can find. Only then can you prove to the world that you’re a man.
Send me an email with your complete motor build specs including cams, cam timing, actual compression ratio. Also your MAF, injectors, intake and exhaust setup. I will build a base chip that will run your car pretty well, then you head to the dyno and send me the AFR and torque data (need runfiles themselves) then I send you another chip back with a revised tune and you dyno again.
