Time-sert
  • hoveringuy
    • Dec 2005
    • 2733
    Time-sert
    Anyone ever time-sert an aluminum block? This reminds me of the Porsche days when head studs pulled out of the magnesium cases and case savers were standard procedure.
    Yeah, I figured I should test-torque the head and sure enough two bolts wouldn't torque next to #5 cyl. Time-sert actually makes a kit for BMW. http://www.timesert.com/html/bmw.html
    Any insight here?
  • dmoney(AB)
    • 1372
    At work when we do headgaskets on a Northstar engine we must time sert every head bolt hole as they always pull threads out. The block is aluminum so I dont see a problem there.
    hope that helps.
    mtech1/2jzgte/r154/275tire
    function>form
    • evil_twin
      • Nov 2007
      • 2965
      Time-serts save lives :)
      Paypal: vdang5@gmail.com
      Delta Auto Care
      2875-C Towerview Road
      Herndon, VA
      703.435.1375
      My Feedback Thread: Evil_Twin
      • Farbin Kaiber
        Lil' Puppet
        • 29502
        Go for it. Your not gonna be running redonkulous boost, so don't worry.
        The Ford 4.6/5.4l's have been the recent "strip-out" engine as of late. Lots of spark plugs blowing out on the road. I saw 15-20 of them last year.
        • hoveringuy
          • Dec 2005
          • 2733
          This seems to be a well-worn path. Lots of Northstar engines are having this problem.
          Baum makes a jig... http://www.baumtools.com/pdf/bmw_M52...6-head_jig.pdf but it's $360.
          The actual Time-Sert kit and inserts is a little over $100.
          Does anyone have the measurements of the headbolt spacing? I could punch out a guide plate on a vertical mill.
          Better yet, does anyone have the Baum tool they'd like to rent to me? Baum says they've sold 12 in the past month alone. I have seen the future...
          • SpecM
            • Oct 2005
            • 4531
            -dear lord yes, northstar engines pull headbolts all the time. The head gaskets never really "blow", they just loosen up. Did the front head on my dad's Olds Aurora about a year ago.
            -Back OT, those timeserts are good stuff. Just a bit pricey.
            1989 cirrisblau-metallic 325i
