m20 or m50 oil pan from e34
  • rkettner
    • Jun 2007
    • 367
    i have got my red label ecu, booster and harness adapter.
    for the oil pan can it be m50 or m20? this would be for the s52 swap.
    thanks
    riley
    i did search and read the dohc thread. its just not specific
  • kylebes1
    • May 2004
    • 2804
    I would like this thread to be locked without an answer because the question is so offensive.
    • Teaguer
      • Sep 2004
      • 6167
      • Stu
        • 4083
        M50 oil pan
        • rkettner
          • Jun 2007
          • 367
          thanks for the answers. thank you for the criticism.
          • BeirBrennerE30
            • 2740
            m50 wont fit in the e30... dont even try
            e30sport.net
            '06 M3 Competition - 6-speed
            '97 Range Rover Vitesse
            • MIKe30
              • Sep 2006
              • 2334
              on a serious note, my stock brake booster isnt fitting... should i use the e36 one?
              • MIKe30
                • Sep 2006
                • 2334
                :p
                • SpecM
                  • Oct 2005
                  • 4531
                  Originally posted by Stu
                  M50 oil pan
                  you give in so easy
                  OP, use the m30 oil pan from a 535i.
                  1989 cirrisblau-metallic 325i
                  • evil_twin
                    • Nov 2007
                    • 2965
                    After I do the swap, will my wheels still fit?
                    Paypal: vdang5@gmail.com
                    Delta Auto Care
                    2875-C Towerview Road
                    Herndon, VA
                    703.435.1375
                    My Feedback Thread: Evil_Twin
                    • Mako18
                      • Jul 2006
                      • 688
                      Well, only if you mount your mirrors on the fenders even then you'd be cutting it close but it should work.
                      • SpecM
                        • Oct 2005
                        • 4531
                        depends...
                        bottlecaps or weaves?
                          • 37829
                          Hahahaha
                          Classic BMW Specialists
                          Grover Beach, CA
                          www.BimmerHeads.com
                          • matt
                            • 3731
                            So, I read this whole thread, and atleast one other, and I still don't know which brake booster to use. I think I'll just use the stock one, I don't see why it won't fit.
                            • FredK
                              • 14761
                              So with the stock 4.10 open diff, do I have to replace it if I use the E36 trans? I'm afraid if I use Z3 shift lever that my gear ratios will be all messed up (2 short).
