m20 or m50 oil pan from e34
  • So Live
    • 2512
    I heard megasquirt will let you adjust differential ratios like in gran turismo.
    edit* i thought your 318is came with a 2.93LSD?!
    -Chris
    • madjurgen
      • May 2005
      • 1203
      Originally posted by MIKe30
      on a serious note, my stock brake booster isnt fitting... should i use the e36 one?
      Considering the retarded thread you started the other day, I wouldnt be so quick to make fun if I were you.
      As time went on, the factory developed the car each year, making it faster, more comfortable, and capable of handling at higher speeds.
      You don’t want this. You want the trickiest, most dangerous, oldest model you can find. Only then can you prove to the world that you’re a man.
      • rkettner
        • Jun 2007
        • 367
        come on guys stop bumping my stupid thread. let it die.
        • MIKe30
          • Sep 2006
          • 2334
          if a certain method to use isn't in the bentley or described in any thread during a SEARCH, imo it's nowhere near retarded.
          • FredK
            • 14761
            drama itt! :giggle:
            • Farbin Kaiber
              Lil' Puppet
              • 29502
              Originally posted by FredK
              So with the stock 4.10 open diff, do I have to replace it if I use the E36 trans? I'm afraid if I use Z3 shift lever that my gear ratios will be all messed up (2 short).
              I hear that will help you at least hold the rev's a bit longer in the turns...
              • yanal
                • Jun 2011
                • 248
                i swear google has the weirdest results sometime !
                Sticky:True e36 one touch windows DIY
                1990 M3
                1992 Mtech (S50 + 5 Lug)
                • GunMetalGrey
                  • Dec 2010
                  • 1499
                  So do I need to use the e90 oilpump and pickup then?
                  • GunMetalGrey
                    • Dec 2010
                    • 1499
                    NVM Searched and found that the e92 m3 pickup works best
