Anyone care to double check my wiring?
  • JGood
    • Jan 2004
    • 7959
    Next question(s):
    From what I understand, I can use either the m50 clutch/flywheel/PP or the m20 stuff, as long as the starter matches. What about the TOB, pivot fork, and slave cylinder? And as for m20 stuff, do single mass 325e parts work, too?
    I have a good flywheel/clutch assembly in my 325e (single mass) and also have a good clutch assembly already bolted to the m50. I don't have an e36 starter though. Which route would you recommend?
    e30 restoration and V8 swap
    24 Hours of Lemons e30 build
    • JGood
      • Jan 2004
      • 7959
      Found this...
      So I guess I answered my question regarding using the single mass 325e parts.
      What if I want to use the m50 clutch/flywheel that's already on the engine? Can I still use the 325e TOB and slave?
      • EtaSport
        • 2853
        Originally posted by JGood
        Found this...
        I've checked several part numbers from bma/fap99 and I always come up with the throw-out bearings being the same for e30 or e36, m20 or m50. I have used s50 throwout bearings as well as m20 with several different clutches. works fine. I'd run the single mass stuff and starter. If you have the big case style starter you will need to shave a mount casting off the block but it will work.
        I switched from an s50 clutch (which I really liked but damn stiff pedal) to an m20 single mass and the accel. was better, a little bit of idle bump, but it holds power just fine.
        Old and improved:
        • JGood
          • Jan 2004
          • 7959
          Cool, thanks. I'll go with the m20 stuff. Just ordered new flywheel and PP bolts (I can't believe I remembered to do that).
          I'm interested to see if I can get every single part ahead of time and do the swap in a weekend. It worked with my 5 speed swap, but this is a bit more involved!
          • EtaSport
            • 2853
            Its possible for a weekend, there are always stupid little things you may end up needing to get, but i had mine running a driving in a weekend, just didnt get exhaust finished. What cooling setup are you going with and which booster? I installed the booster prior to the actual swap.
            Old and improved:
            • JGood
              • Jan 2004
              • 7959
              I just finished making my wiring adapter tonight. Headers will be here tomorrow, I'll drop it off at the exhaust shop after the swap is done for the rest (magnaflow cat, borla muffler, 2.5" stainless piping).
              I'm gonna use an e21 booster which I'm picking up Wednesday, and probably just bore out the clevis pin to make the job quicker and easier.
              I have an m42 radiator on the way. What hoses are considered best for this? M20 lower and cut m50 upper? How am I going to have to jimmy rig this thing to my early model rad support?
              What about all the random ass hoses hanging off the engine... there's all kinds of shit there. Looks like they go to where the airbox was. I should have taken pics of this thing in the car...
              Nice thing is I have a 4 day weekend off of work, so from Thursday night til Monday night, I'd like to get this thing running. I have 2 other vehicles to use, but one is a gutted track car and the other gets 13 mpg :(
              • FredK
                • 14761
                I used an M50 lower and a hose from Advance Auto, some random GM hose or something cut down to size. I could have used the M50 hose but I cut it too short. It's also HELL to squeeze it onto the thermostat housing because the flanged, larger diameter section gets cut off in order to fit it properly.
                Use some rubber bumpers, maybe like subwoofer mounting feet, on the lower rad mounts, and use a late model upper bracket. Beej 86 325es used some bolts, washers, and rubber stoppers to get his radiator to the right height. Or, you can weld on the proper late model expansion tank brackets, but I guarantee you'll be waiting for parts from Germany for a few weeks.
                BIGCRY. FREDK DON'T CARE.
                Just kidding. On an M50, you can use the realoem diagrams for the most part to determine where the hoses go. Essentially, the spider hose is the most important hose. It goes from the timing cover to the heater inlet, and also branches off in the middle to the expansion tank (goes on the M42 lower fitting) and the throttle body.
                A small diameter hose returns the coolant from the throttle body back to the head on a small brass fitting. There is an odd looking coil of hoses that goes to the where the airbox goes, and terminates in a plastic/brass thermostat-lookin' thing, but you can remove this hose.
                Well, you're not totally up the creek, then. :D But it sure lights a fire under your ass to get things done!
                Good luck JGood.
                • JGood
                  • Jan 2004
                  • 7959
                  Awesome, thanks for clearing all that up!
                  Are my motor mounts on right? (see pics below)
                  Which fuel line is which? Also, there is a coolant hose that kind of goes near the heater core pipes, but isn't facing the firewall, it runs parallel to it... I have a pic that shows it below.
                  I just remembered I have to get my flywheel machined to clear the pan, I may just try to grind the pan so that I don't have to deal with that huge holdup.
                  I was originally going to just swap in a good 220k mile b25 to replace this 250k mile b27 that is on it's last leg (burning 1qt every 500 miles or so)... but I ended up getting this motor for free... and so far the only things I've paid for are the headers, m42 radiator, the e28 mounts, and I'll have to pay the exhaust shop.
                  Here's a bunch pics I took tonight of my new garage I just got, and some random motor pics:
                  • FredK
                    • 14761
                    I think the mnemonic I developed was silver = supply. So, black = return for the fuel lines. But if it doesn't start, I disavow any responsibility.
                    • Jason89i
                      • Sep 2004
                      • 875
                      Next question(s):
                      ............ What about the TOB, pivot fork, and slave cylinder? And as for m20 stuff, do single mass 325e parts work, too?
                      sounds like you have it figured out. but, just a heads up on the older "e" cars.
                      some "e" cars had dual mass flywheels. i have found that SOME of the g265's are different than the "i" or single mass flywheel cars. going from "e" dual mass to single mass can be trickey. read to the end..... http://www.r3vlimited.com/board/show...ghlight=CLUTCH
                      cheers, jason
                      • JGood
                        • Jan 2004
                        • 7959
                        Thanks for the heads up. The car was actually started life as an automatic, then I did a five speed conversion with single mass 325e parts a few years ago, so I should be good to go.
                        • OoPEZoO
                          • Jan 2007
                          • 83
                          Hey.....I'm sure we'll talk about it tomorrow, but are planning on tearing into it this weekend? I'm waiting for some motorcycle parts, but if I don't ge them I should have my whole weekend open if you need a hand.
                          I'll drink beer and bark orders from the lounge chair in your crows nest
                          • JGood
                            • Jan 2004
                            • 7959
                            Hell yeah man! I'm sure I could use all the help I can get. And the mini-fridge will be stocked!
                            • yberther
                              • 1246
                              sweet garage and loft ;)
                              Flickr
                              Originally posted by Indecline06
                              For some reason, when I get super duper ultra stoned... The M30 motor reminds me of big bird from sesame street.
                              • Jason89i
                                • Sep 2004
                                • 875
                                Might want to run a compression test. i think all that oil is going out cyl #2. stems or rings? cheers, jason
