what won't work after a M50 swap
  • Hartge H26
    • Mar 2004
    • 102
    I had a swap done and just want to see what things are not expected to work after the conversion. So far the following don't work:
    obc:
    fuel range
    consumption
    fuel consumption on tach
    over head board: (lights are on)
    engine oil
    coolant
    Washer fluid
    My ac fan comes on but no power to the compressor.
    And now I have a power drain somehwere that's killing the battery.
    Thanks
  • hoveringuy
    • Dec 2005
    • 2749
    Every single one of those things should work. On my car, if I didn't tell you it had an M50 you would never know (except for the extra power).
    Your OBC and econometer will read inflated mileage figure due to the larger injectors, but that can be corrected as well.
    • Hartge H26
      • Mar 2004
      • 102
      so how do I start fixing these things... any help is appreciated.
      • hoveringuy
        • Dec 2005
        • 2749
        If those items worked before the swap and now they don't work, I would say most of the problem is in your harness adapter. Who did your swap? Sounds like half of your harness wires aren't connected.
        • Hartge H26
          • Mar 2004
          • 102
          not connected.... from the round plug on the firewall
