how to make engine run outside of car?
  • lifeiskaos
    • 1709
    as the title states, what is required to test an engine before putting it in the car? obviously you need a battery, and gas. i imagine it wouldnt be very hard to make a fuel cell with a stock fuel pump. mainly curious about wiring. what to do with the main harness connector, and if block itself (or engine stand?) is sufficient for the main ground. assume its an m50, although it should be the same for m50/m52/s50/s52. thanks
  • bwh13
    • Jan 2007
    • 437
    The test stand should be enough of a ground as long as the battery is attached to it. Fuel and spark and coolant, if you want to run it for more than a minute or two...that's all you need.
    • gregslow318i
      • Sep 2007
      • 1918
      how are you going to use a starter? you need a trany also? my buddy once started a sbc buy sitting on it and pouring gas in to the carb was hella funny
      looking for a e30m50 swap harness adapter pm me $150 shipped
      email nitroman12@gmail.com
      • 88E30M50
        • Apr 2008
        • 48
        Would an engine stand be strong enough to keep the torque from tipping the engine when it fires? Most engine stands I've seen are pretty stable for overhaul work, but would not be the best choice for a running engine.
        Tim
        Indianapolis, IN, USA
        88 325is (M50)
        92 525iT (5 speed)
        98 328is
        2011 535is
        69 Fiat Spider
        68 Fiat Spider (122nd chassis built for the US)
        • Jean
          • 18228
          You'll probably want to build something custom with enough weight to hold it all in place. search google, I've seen someone do this for an ls1/2 ....
          • Farbin Kaiber
            Lil' Puppet
            • 29502
            Yeah, most engine dyno shops have the setup you require. The crazy glowing BMW header pic came from a stand like this.
            • kronus
              • Apr 2008
              • 13032
              Stupid question - you don't need the ECU and harness to control stuff in order for the engine to start?
              Actually, now that I'm thinking about it, m20 ignition is fixed timing, because it uses a distributor. The incoming air is controlled by the throttle body... so the only thing the ECU adjusts is the fuel delivery?
              cars beep boop
              • matt
                • 3732
                The distributor only decides which cylinder is firing, it doesn't decide the ignition timing. The ECU does that.
                Running a motor out of a car, on any sort of stand not designed for the purpose, is a really bad idea.
                • kronus
                  • Apr 2008
                  • 13032
                  Ah, I see now. Ignition timing is adjustable within the window where the rotor and cap are in contact.
                  cars beep boop
                  • hoveringuy
                    • Dec 2005
                    • 2747
                    Yep, that's exactly what I'll be doing (hence the M54 foolishness thread title.)
                    I have too many variables going on to feel comfortable just putting the motor in the car... I really wish I had a spare chassis just to hold the motor and give it life support while I get it running.
                    I think a $300 e30 shell with a working fuel tank and battery would make a heck of a test stand.
                    In the absence of that, I'll build a cradle with wheels to roll it outside. Fuel pump in a 5gallon bucket with lid. Battery on the stand.
                    It frightens me already.
                    • devonjordan
                      • Jul 2006
                      • 2386
                      Wow, good luck with that. Be sure to post the vid of the ensuing disaster, haha.
                      Hemingway said it best. “There are only three sports: bullfighting, motor racing, and mountaineering; all the rest are merely games.”
                      Help a brother out, buy your detailing products here...
                      • matt
                        • 3732
                        Strange, I just gave away a $300 e30 with a fuel tank and no motor. Didnt have any takers for the longest time at $300, so I sold it to a scrapper for $100.
                        • lifeiskaos
                          • 1709
                          thanks for the help guys. so it can theoretically be done without having to plug in any of the wires on the main harness plug to the chassis?
                          • matt
                            • 3732
                            No, it can't be done WITHOUT all that stuff.
                            • Adrian_Visser
                              • Jun 2006
                              • 2823
                              why go through all this trouble?
                              '89 Alpine S52 with goodies
