Checking for spark on an M50
  • 88E30M50
    • Apr 2008
    • 48
    Hey Guys,
    I've been banging my head against the no-start issue for a couple of weeks now and am not getting anywere. I think the wiring is correct and have traced every wire in the connectors through the ETM and then back probed the wires to verify what I've found. I've checked the crank and cam sensors and the resistance values I get from the ECM connector match what I get on my running 525. I've swapped MAF sensors, checked coil packs, replaced the plugs and still get nothing but an occasional backfire and lightly fouled plugs when I try to start the beast.
    So, I back to the basics and need to verify spark. The issue is, I have no idea how to do that on an M50. Bentley's is of no use except to warn about ECU damage. Does anyone have a good way to check for spark? I was thinking of pulling the coil pack connector, attaching a spare coil and boot and grounding both the coil pack attachment point and the plug. Will that work or am I asking for a fried ECU?
    Any help would be greatly appreciated. I'd really love to get the car running before fall sets in.
    Tim
    Indianapolis, IN, USA
    88 325is (M50)
    92 525iT (5 speed)
    98 328is
    2011 535is
    69 Fiat Spider
    68 Fiat Spider (122nd chassis built for the US)
  • gregslow318i
    • Sep 2007
    • 1918
    yeha just pull a coil and plug in a spark plug and ground the tip and turn it over. try not to shock the sh*t out of your self!
    looking for a e30m50 swap harness adapter pm me $150 shipped
    email nitroman12@gmail.com
    • evil_twin
      • Nov 2007
      • 2965
      IF you hold onto the coil and it shocks you a little bit, then it's good. So hold onto it. :)
      Are you sure you're getting fuel into it? Do you hear your fuel pump. When you pull off the lines and crank it does fuel come out of 1 line?
      Paypal: vdang5@gmail.com
      Delta Auto Care
      2875-C Towerview Road
      Herndon, VA
      703.435.1375
      My Feedback Thread: Evil_Twin
      • Jay325
        • Sep 2004
        • 67
        I would lean more towards a fuel issue.....You could spray some starting fluid through the TB and see if it starts. You could buy an inductive coil on plug tester, I have seen them in many tool catalogs or online (autotoolmart, toolsource, autospecialtytools) To me it sounds more like lack of fuel if it stumbles and fouls plugs.
        • 88E30M50
          • Apr 2008
          • 48
          I think I'm Ok with the fuel pump. I have a fuel pressure gauge attached and am getting around 50psi while cranking. If spark checks out Ok, I'll take a look at the injectors themselves.
          Thanks,
          Tim
          88 325is (M50)
          92 525iT (5 speed)
          98 328is
          2011 535is
          69 Fiat Spider
          • evil_twin
            • Nov 2007
            • 2965
            Well there's is a feed and a return line. Do you have that plugged in correctly? Even if you have 50psi at the gauge, you might be just running into a brick wall by having the lines flipped incorrectly.
            Delta Auto Care
            Herndon, VA
            703.435.1375
            • 88E30M50
              • Apr 2008
              • 48
              Good thought but, I think I've got that right. Feed at the front, return at the regulator. The gauge is connected at the front of the rail and is measuring rail pressure.
              Thanks,
              Tim
              88 325is (M50)
              92 525iT (5 speed)
              98 328is
              2011 535is
              69 Fiat Spider
              • evil_twin
                • Nov 2007
                • 2965
                Okay, now did you pull apart your DME to put a chip in?
                Delta Auto Care
                Herndon, VA
                703.435.1375
                • 88E30M50
                  • Apr 2008
                  • 48
                  I did pull the DME to put the chip in. I have a 525iT that I've swapped DMEs back and forth between several times. The DMEs all seem to work in the 5'er, but no joy on the 3.
                  Thanks,
                  Tim
                  88 325is (M50)
                  92 525iT (5 speed)
                  98 328is
                  2011 535is
                  69 Fiat Spider
                  • JGood
                    • Jan 2004
                    • 7959
                    Man, I'm in the same boat. 85 325e with 94 525i m50. No spark, but everything checks out... and I mean everything.
                    It's fucking bullshit.
                    I'm about 2 days away from swapping the m20b27 back in... no joke.
                    e30 restoration and V8 swap
                    24 Hours of Lemons e30 build
                    • 88E30M50
                      • Apr 2008
                      • 48
                      I hear you on that. I've tossed that idea around a couple of times, but need to press on. Tonight, I swapped fuel rails, injectors and FPR, checked the injector pulse via noid lights and checked spark. Still nothing. I'm convinced that it must be the cam or crank sensor and am about to pick both up. If that does not do the trick, I don't know where I'll go from here. I'll let you know what I happens when I swap the sensors in. I checked both of my sensors via the ECU plug and get almost identical readings to the ones in my 525iT. I figure $150 is easier to swallow than the $500 an oscilloscope would set me back (and that's for a cheap one).
                      Tim
                      88 325is (M50)
                      92 525iT (5 speed)
                      98 328is
                      2011 535is
                      69 Fiat Spider
