OK, so I finally got everything put together correctly and now I have the infamous no fuel no spark issue. I have a Non-Vanos M50 from a 92 325i, this engine and harness ran fine before I pulled if from the donor car.
Let me know if I've missed somethingHere is what I have double checked so far..
1. Grounds (Total of 2) - Harness ground and engine to chasis ground are good.
2. Power wires (Total of 4) - Main harness, both E30 fuse box, and diag. power wires all
good.
3. Main relay = Good
*4. Jumpering the fuel pump relay socket pin 30-87 does not seem to turn on the fuel pump, also, I checked the green/purple wire on the engine harness plug side and it has no voltage.
5. 402 DME tested fine when I swapped it into my wife's 92 325is this afternoon so I know to computer is good.
I'm worn out and sooo disappointed, I was really hoping to get this finished up before my last chemo treatment on Thursday. If anyone has any ideas please chime in.
good.
