The Infamous No Fuel - No Spark
  • SpecM
    • Oct 2005
    • 4531
    #31
    Originally posted by RobertK
    Put my ECU in Tara's car and it starts her car right up.
    I would say the problem's in the m50 harness
    1989 cirrisblau-metallic 325i
    • RobertK
      Kicked cancer's ASS.
      • Jun 2005
      • 5864
      #32
      Do you mean the engine harness or the harness adapter?
      • SpecM
        • Oct 2005
        • 4531
        #33
        I say engine harness, maybe you damaged it on the install
        but that's a guess
        • atomic
          • Jun 2007
          • 5691
          #34
          Put 'ole smokey back in???
          :D
          • Stevie30
            • Apr 2007
            • 1534
            #35
            Please....No (gasp, gasp) Get er done!
            1991 325ic and 1991 318is
            • rs4pro3
              • 5808
              #36
              Found another ground I over looked on the ecu connector for you to check out it's pin 28.
              Also I found that there is an automatic tranny switch that could possibly be on your harness, it goes to pin 65 on the ecu connector, check and make sure you have 12volt on that wire. The diagram dosn't show how the manual cars deal with that wire.
              85 325e 2.7 ITB'd stroker
              • golde30
                • 11464
                #37
                i had an e36 auto harness for my 24v swap, i just cut out all the wires that went to the tranny dme plug, diag port, and connector(looks like o2 plug) out of the harness with no ill effects.
                IG: @Baye30
                • 318isbmw
                  • Nov 2005
                  • 2843
                  #38
                  Even though they never were disconnected, I would check the crank and cam sensors. Common problem is those go bad so the ecu won't turn on spark. I'd hate to see those be the problem with all of the work being done, and their both a simple test, the only issue is getting to the connectors.
                  • JGood
                    • Jan 2004
                    • 7959
                    #39
                    You can test the crank sensor via pin 16 and 43 (IIRC) at the DME. You are usually looking for 540 ohms at the sensor, so figure a little less at the DME. I had 537 at the sensor and ~520 at the DME.
                    e30 restoration and V8 swap
                    24 Hours of Lemons e30 build
                    • RobertK
                      • Jun 2005
                      • 5864
                      #40
                      If the cam or CPS was bad wouldn't the fuel pump still turn on?
                      Also, this harness came from a manual E36 so would that automatic pin still apply?
                      • rs4pro3
                        • 5808
                        #41
                        no as the ecu has to see that the engine is actually cranking to kick on both the pumps and send spark. So a bad crank sensor could cause your problems.
                        I'm not sure about the park switch thing, usually on the diagrams it shows a separate diagram for manual and automatic cars, this diagram doesn't show that. So just check for 12-volts on pin #65 of the ecu connector
                        • FredK
                          • 14761
                          #42
                          I know that the ECU has to see cranking before it sends a signal to the fuel pump for the earlier Motronic systems, but is this true for the 413 DME? I hear a buzzing right when I turn the key to the ON position, but it is a short buzz.
                          • jakeb
                            • 1909
                            #43
                            Isn't the buzz the ICV?
                            www.classicdaily.net
                            1970 m42 swapped 2002
                            1985 LS1/T56 Swapped e28 (557e)
                            www.blunttech.com - For all your parts needs
                            Follow me on Instagram for constant build updates @classicdaily
                            https://www.facebook.com/ClassicDailyLLC
                            • RobertK
                              • Jun 2005
                              • 5864
                              #44
                              Yeah, usually the buzzing is the ICV adjusting itself.
                              So next on the agenda this afternoon is test power to the fuel injectors, check those pins on the DME plug and then check the CPS.
                              • RobertK
                                • Jun 2005
                                • 5864
                                #45
                                Also, would a bad Cam sensor also cause the fuel pump not to turn on?
