Need help m52 swap
  • MaRsUpEr
    • 36
    Need help m52 swap
    hiiiiiiiii everybody,
    am new here... Am looking for some advices
    am planing for M52 Swap for my e30, I wanna know what exactly do I need for that and am planing to do soon, in my country they are not that experts in swaping on e30, so I NEED HELP PLEASE
    as I've seen in all m52 swaps they removed the clutch fan
    if I do that here the temp. will go up in 10 minutes, please give me some advices
    Thanksssssssss
    __________________________________________________ ____________________________________________
    BMW E30 m20b27 NOW | Korando 4x4 (Engine: Mercedes 320) NOW | Chev. cavalier 1998 moded History | BMW e36 m52b28 History
  • FredK
    • 14752
    You can run an electric fan, such as a Spal 16". Together with a temperature switch or manual switch, this will allow you to maintain reasonable temperatures even when stopped in traffic.
    • mentaleeill
      • 850
      wire it to the factory fans high speed wire. that wat you can put it on manually with the a.c. switch or it will come on automatically at a certain temp (depends on switch used).
      • dpgrand
        • 179
        based upon what I have learned in the past few days reading up on stuff an electric fan is the way to go
        • MaRsUpEr
          • 36
          thanks :) guys
          some more questions
          - what are the mounts should i use for the engine.
          - for starting the swap what should I order other than:
          1) M52 engine with all parts and harness ECU
          2) ZF Manual transmission
          - what about the Differential.
          - Can change these later on (Steering box, Braking system).
          - For sure I should change the exhust system?.
          SEEMS AM ASKING TOO MUCH :hitler:
          is there is any Comprehensive THREAD/LINK about this swap.
          that will keep my mouth shut for the time being :D :p
          Thanks
          • dpgrand
            • 179
            there is a sticky on the top of this swap forum
            • Uber E30
              • 1409
              you will need a brake booster, an e36 drive shaft, differential depending on your ratio, headers, and lots of various other bits.
              -Alex
              • MaRsUpEr
                • 36
                swaping m50 is same like m52 vanos?
                nothing special about m52 vanos?
                • dpgrand
                  • 179
                  some m50's are vanos and some are non vanos. If you use an m52, you will have to convert it to OBDI from OBDII - this requires the intake manifold from an m50 and some other sensors i believe.
                  • MaRsUpEr
                    • 36
                    where do I find about these other sensors :(
                    that's why am asking about a link to go
                    which tell exactly what i have to do for the m52 swap
                    • dpgrand
                      • 179
                      here's a start
                      • Uber E30
                        • 1409
                        Really? I was under the impression that you didnt HAVE to, you just got better performance from obdI
                        -Alex
                        • SpecM
                          • Oct 2005
                          • 4531
                          you're right, the OBD II mani can be used
                          1989 cirrisblau-metallic 325i
                          • daveyboi
                            • 23
                            Originally posted by MaRsUpEr
                            thanks :) guys
                            Should be pretty helpful :) Good luck!
                            "with a six pack of pale, listen to the hoods and watch the double blues boys prevail"
                            (OO=[][]=OO) - www.eurocca.net
