TMS Oil Temperature Sensor Flange
  • dude8383
    • Jan 2005
    • 10387
    Any of you guys seen this?
    http://www.turnermotorsport.com/html...ppingZip=11236
    What do you think...looks a nice easy solution for temp sender.
  • trelms
    • 29
    Dope. Finally.
    • Dominic49
      • Feb 2007
      • 1373
      word only wish they machined a recess for the wire to sit flush in...
      • 318isbmw
        • Nov 2005
        • 2843
        Now that's cool. May have to save up and get me one.
        • Jean
          • 18228
          Nice, but in place of oil Level ?
          • Dominic49
            • Feb 2007
            • 1373
            just pretend you drive an m42.... dip stick ftw!
            • woky
              • Jan 2008
              • 49
              A recess to run the wire for the sender, or at least some method to secure it out of the way would have been a nice touch. Having said that, I'm getting one for my M52.
              • hugh jass
                • 2220
                You either have to secure the wire to the sender and then screw it in by slipping some pliers up in the recess, or you have to screw the sender in and the try to wiggle the wire and clip up to secure it to the sender. I have it on my car and honestly I'm thinking of removing it. There is simply not enough room to torque the sender down properly and connect the wire to the sender in the narrow recess. Its not a good design.
                ______________________
                ex-Chief Operating Officer
                Blunt Tech Industries
                West Coast and Pacific Rim
                • dude8383
                  • Jan 2005
                  • 10387
                  nice...i ordered one too. doesn't look like there will be any issues installing it imo.
                  • hoveringuy
                    • Dec 2005
                    • 2742
                    I'm in the weird position that I have an oil temp sender but not the e30 water temp sender. The M54 already has the oil pressure sender behind the oil filter.
                    So, which is more important, having oil temp or water temp? Could I have oil temp without water temp?
                    • matt
                      • 3732
                      The 413 wants a water temp signal.
                      The MS43 wants both...
                      • hoveringuy
                        • Dec 2005
                        • 2742
                        No, I mean for my cluster gauge
                        • matt
                          • 3732
                          Use water temp. More useful to tell you if you have an overheating or coolant loss situation. Or work out a switch to use both... that would be cool.
