S52 Oil Seperator / PCV system
  • dpgrand
    • 179
    Are people using the oil seperator? #2 in this pic:
    The problem is that to do the swap, a e34 dipstick tube is used; however, it doesn't have the breather opening that #6 is connected to? The only solution that I can think of is combining a e34 and e36 dipstick tube into one. Is there a true solution to this?
  • Drew325is
    • Oct 2004
    • 520
    I've seen a few people add a breather to the E34 dipstick. I ended up running #6 into a catch can instead of back into the sump.
    • hoveringuy
      • Dec 2005
      • 2715
      See my thread under "M54 foolishness...". I added the section to my e34 dipstick tube so the seperator could drain into the pan.
      • dpgrand
        • 179
        Thanks! For anyone else interested, here is hoveringuy's picture:
        • Jean
          • 18228
          What are the cons and pros of running the pcv back into the oil pan? There is gotta be some kind of function behind #2?
          • loonibab325i
            • Dec 2005
            • 770
            I deleted mine, it goes straight to the intake mani.
            s52 0-150mph & more http://www.youtube.com/loonibab325i
            • WillisE30
              • Jan 2007
              • 831
              Pure genius.:giggle:
              The PCV system on the newer cars M52 and up really is based off a cyclone seperator that instead of dumping the gasses back into the intake (to presumably be burned during combustion) seperates the oil vapor and other gas and drains the oil back into the dipstick tube. In theory your engine will use less oil this way which becomes a more serious issue as oil change intervals continue to be extended out to lower maintenance costs.
              sigpicFormer professional wrench thrower.
              Current:
              1988 325is S52
              Former:
              2008 Sparkling Graphite M3 Sedan(victim of home ownership)
              1988 M5
              1996 328is
              • dpgrand
                • 179
                It separates the gases and oil mist from the mixture that seeps into the crankcase between the piston rings and block. This way, the gases aren't just released into the atmosphere to harm the ozone, AND the oil won't gunk up your air intake. Instead, the gas goes back through the engine, and the oil goes back into the crankcase.
                • Drew325is
                  • Oct 2004
                  • 520
                  I have heard some people say that once the oil is misted like that you don't really want to keep it...but I'm not sure how much of a threat to anything that really is.
                  Out of interest, I'm using an E30 M3 air/oil seperator on my M52 and collecting into a sealed tank...after a 1000-2000km there's bugger-all oil in the tank - and the butterfly still feels dry. So it's very little oil we're talking about - which I think probably negates any likelihood that the misted oil, even if it is bad, is going to significantly contaminate the rest of the oil. Anyway it'll be interesting to see just how much oil I catch over the years from the camshaft ventilation.
                  • Lenwood
                    • Mar 2012
                    • 100
                    ccv
                    i tig welded a return tube to an e34 dipstick. i gonna try an s14 oil seperator or go the catch can route. will update shortly
                    1989 325ix(sold)
                    1989 325i sedan s52 powa (current)
                    • Wanganstyle
                      • 2828
                      The air oil separation device is only
                      Really on obd2 cars for emissions.
                      Similar logic is why the n54/55 engines have no dipstick; no vapor escape = less emissions
                      If one actually desired a high quality air oil separator / catch can Radium makes a great product proven in circuit use. You won’t need this for street use, unless your engine is in crappy shape and just sucking in oil at idle from blow by ; might be a useful band aid in that case
                      Why you need it: When properly designed and installed, an oil catch can will prevent sludge buildup in the intake, intercooler, throttle body, etc. They effectively raise fuel octane and increase engine performance with cleaner inlet air. Also, excessive oil collection can be an indicator of a damaged engine.  Radium s
                      If your engine is crap nothing will band aid it to be not crap.
