Weird whine, maybe alternator?
    I have a whining sound coming from the front of the engine. It's loud enough to hear up to about 50 mph before wind noise drones it out. It's like a whining, but it's not high pitched. With the screwdriver-to-the-ear test it seems loudest on the alternator. I hit every pulley bearing with WD-40 while it was running and it didn't change the sound.
    The sound increases with RPM, and is not dependent on load (it will make noise under acceleration and deceleration). I'm really thinking it's the alternator, but would like to know if anyone has experience with something like this before I go buying a new one.
    Thanks
    e30 restoration and V8 swap
    24 Hours of Lemons e30 build
    My AC belt made a racket when it was worn. Also, it has a tendency to walk on the AC clutch pully when you run the car haaard, hanging half on,half off the pully.
    Worn idler pulleys can be noisy as well. There's a post on BFc on rebuilding/repacking pulleys in the E36 section....
    Ed
    1988 E30/S50...now with S52; Track
    1994 Miata R; ES Solo2
    1998 Lexus LX470; Wife (Slee'd anyway)
    2002 BMW 530i; A+ Commuter
    2002 BMW 325iT; Sport/Premium 5-speed
    2011 21' EconoTrailer
      I was just about to say the same thing. the idler can sound like its coming form the alternator. the tensioner telescopes through the oil filter housing with the screwdriver test. Pop the belt off and spin pulleys by hand. I have also seen a few whining alternators too.
        Will do. Thanks guys!
