S52 Oil pump-to-block gasket
    Is there one? I only see the gasket for the suction pipe (#12) but no gasket for the mating surface between the pump and block. Can anyone check theirs?
    No. There is a piece of pipe (I guess you can call it) that sticks out of the block and into the hole on the pump.
    My 2.9L Build!
      You sure about that? I'm not talking about the front of the pump, I'm talking about the rear, where there are 3 holes, right above the control valve. I see that the front has the 2 alignment dowels, where #16 is used.
      The surface looks pretty flat on the back section look pretty flat, maybe flat enough to not require a gasket?
