Still trying to clear 1281 code
  • bwh13
    • Jan 2007
    • 437
    The code still won't go away even after I've driven the car for about 45 minutes.
    I've been getting the code ever since I first hooked everything up and started the engine. I tried several 413 Red label's when I first got it started, but they all give the same code.
    I'm running the E34 harness with Treehouse adapter, S52 OBDI.
    The DME has 2 battery input locations, #26 and #54. #26 comes from the same splice that send power to the fuel pump relay & DME relay, so it obviously is hot since those parts work.
    #54 comes from the splice that sends power to the IACV, evap valve and the cam actuator (I'm guessing this is the VANOS solenoid). Those parts all seem to work, so I'm stumped as to why the code is still there.
    I read someplace that this code will clear after driving the car enough to charge up the battery (if the battery was getting down on voltage), so it should have cleared itself by now. Do the codes clear themselves or do I have to disconnect the battery to do that?
    Any help appreciated.
  • surebimmer
    • Jan 2004
    • 978
    Codes do not clear them selfs. They may become 'currently not present' but they will still be stored and CEL still on.
    Disconnecting the battery will not clear the fc. You will need a reset tool.
    • 1990m3
      • 1180
      he's right, you need a reset tool to reset the fault code
      • bwh13
        • Jan 2007
        • 437
        Thanks very much. I have been wondering about this for the past 2 months. For some reason I thought disconnecting the battery would clear the codes...
