Ok heres a new one, its not one of those "No start threads" its a "No kill thread".
So heres the problem, I got the car started(Euro S50B30 with EWS) and could not turn it off, I had to pull the engine control relay out to kill the car.
One thing I noticed that the EWS relay(silver box) takes about 10sec to open(click) after the key in switched off, not sure it this is what kept the engine running.
Also the green/violet(e36 wire 13 on the harness) I had used for the fuel pump relay had no power for some reason, so I just used the green/white wire(e36 pin 22 on the harness) could this have caused the problem?
Can someone tell me what turns the car off?
