Question about running the zf tranny...
    If I run the zf tranny, is it a must to use the stock e30 shifter carrier/linkage/shifter? Could I use my e36 zf shift carrier/linkage/shifter?
    SINdelle:E36 M3 5-Lug | 17x8 & 17x9 BBS RS | S52/ZF | 2.93LSD/3.5HFM/24lb Injectors/C&S Chip[B]SOLD[B]
    As long as its not an early style plate shifter, those are your only 2 options (excluding getting an aftermarket SSK)
      all e36 besides selector rod thats from 325i e30
      www.gutenparts.com
        My setup uses the E30 carrier, M3 selector rod and some Z3 lever that I bent the living shit out of to get the angles right. It has a pretty short throw though... :-)
        '89 325is S50 Track Montser
        '04 X5 Daily/Tow Vehicle
        http://www.avarestoration.com
        http://www.myspace.com/brendanfiddle
        Click here if you want to be my zombie slave...
        http://www.youtube.com/user/Fidhle007
          using all e36: selector, carrier and lever...only using the e30 linkage mount. perfectly aligned and centered.
          No more e30s for me.
          88 black BMW OBDII 332is dedicated track [sold]
          88 BMW OBDII bronzit 332is [RIP 03/08]
          91 BMW 325i [sold]
          86 Corolla 'Ae86' HB 20v trd [sold]
          http://youtube.com/watch?v=pTj7Hn9v5Rs
            Linkage mount? Which is that?
              its at the rear of the carrier. http://www.realoem.com/bmw/showparts...27&hg=25&fg=05
              look at number 4.
              www.gutenparts.com
                I see. The part bolted to the chassis. Ha. Anyways, I guess I'm going to use all my e36 parts then but leave the stock carrier mount.
                  Originally posted by etxxz View Post
                  using all e36: Selector, carrier and lever...only using the e30 linkage mount. Perfectly aligned and centered.
                  +1
                    bringing this thread back from the dead: Which e36 selector, carrier, and lever do you use? 328/325/318?
                    And which linkage mount do you use? early model/ late model? 325/318?
                    ^M52B28^
                      I'm using all 328i parts on mine except for the linkage mount which is the stock 318is mount. Works fine but the shifter sits to the right of center on my car.
                      -Justin
                      Current: BMWless for now... '15 Grand Cherokee & '03 Mach 1
                        I used the e36 328is shifter arm, e36 328is selector rod, and e30 325is linkage mount. I bent the mount slightly so that the shifter sits directly in the middle. I just ordered a z3 short shifter and zhp knob, will report back with how awesome the setup is
                        ^M52B28^
                          im using the entire E36 shifter setup except the rear body mount is E30.
                          '96 328 donor car IIRC.
                          Full Build Thread Here
                            Got everything installed and its perfect! the shifter sits directly in the middle and the z3/zhp combo is great; very precise (with new bushings and mounts), as well as very smooth. Definitely recommend it, FCP Euro has a z3 shifter kit for $150
                            ^M52B28^
                              ^This.
                              Works fine.
                              Originally posted by ebelements
                              Also, for those who don't know, negative camber is the greatest thing since sliced bread(panera). Even tire wear is for city busses and the elderly.
