Bad starter clicked, new starter does nothing
  • jahnaboi
    • Oct 2006
    • 1742
    Lol... glad to hear you got it solved...
    SINdelle:E36 M3 5-Lug | 17x8 & 17x9 BBS RS | S52/ZF | 2.93LSD/3.5HFM/24lb Injectors/C&S Chip[B]SOLD[B]
    • BenM
      • 2184
      Can anyone expand on the earlier model unloader relay wiring? I realize that it in the earlier cars they are triggered via the black/yellow C101 pin 18 (Ignition switch), but is there any other wiring that needs to be done to make them (the unloader relays) function properly.
      Thanks,
      Ben
      Originally posted by BillBrasky
      E36's are the Stephen Baldwin of the 3 series family. They barely hold everything together and they only sold a lot because of the popularity of their older sibling.
      1991 318i Alpine II - S50/5-lug swapped - track car
      1989 325i Cirrusblau - Daily
      1970 2500 - Malaga over Grey Cloth
      2012 F350 6.7PSD
      • FredK
        • 14762
        Not really? As long as the body wiring hasn't been touched, the only remaining wire that would make K5/K7 work would be connecting terminal 50 on the starter to C101 pin 18.
        • BenM
          • 2184
          Thanks Fred. By not wiring the C101 Pin 18 to Terminal 50 on the starter would mean the relays would be permanently unloaded and the windows, etc. would not work, correct?
          2012 F350 6.7PSD
          • FredK
            • 14762
            Yep. If you don't make that connection, then the power windows, HVAC blower motor, and other high current stuff won't work.
            • BenM
              • 2184
              Great, thanks. Am I correct to assume that this should be done in addition to the X20 Pin 18 (Starter Ignition)?
              2012 F350 6.7PSD
              • FredK
                • 14762
                X20 pin 18 = starter terminal 50. So just connect x20p18 to c101p18.
                • BenM
                  • 2184
                  doh. Thanks man.
                  2012 F350 6.7PSD
