What drive shaft set up do I need ! 91 318is stock 240 trans with m52 conversion ?
Drive shaft help!
I'm stupid.
Lol... update
"Getrag 240. () A stock M42 cross member/tranny mounts may be used. The clutch/starter must be from an M20. The throw out bearing for the clutch must be from a euro 323i
Part available here:
http://www.pelicanparts.com/cgi-bin/...I1.x=2&I1.y=11
Part number info found here: http://www.realoem.com/bmw/showparts...11&hg=21&fg=05
Any M5x E36 manual drive shaft will work with an E30 CSB. Suggested rear end - <=3.25
*M20 stock flywheels require shaving 1/8" on the back side to avoid hitting the oil pan."
SINdelle:E36 M3 5-Lug | 17x8 & 17x9 BBS RS | S52/ZF | 2.93LSD/3.5HFM/24lb Injectors/C&S Chip[B]SOLD[B]Comment
Ok won't the m52 flywheel/clutch/starter work with the 240 trans ?I'm stupid.
Lol... update
*M20 stock flywheels require shaving 1/8" on the back side to avoid hitting the oil pan."sigpic I HATE SPEED BUMPS !!!!!Comment
uh oh, so does that mean an m20 wont work with G240 internals and 318is driveshaft??
i know this is 24v swap section but the m20 is coming out of the car that is getting a 24v so it still counts! :D Just happens to be going into my 318is since the m42 just died...
