s52 rebuild cost... yikes!!!
  • MIKe30
    • Sep 2006
    • 2334
    Had no compression in cylinder 5 when I bought the motor (was sold to me as "perfectly good", but thats a whole 'nother story.) Since no compression on 5, and the donor vehicle was involved in a rollover, I figured bottom end should be looked at and rehoned at the very minimum. (some scoring present on 2 cylinders also).
    Was just sourcing parts so I can have this sucker put back together and damn. It starts to add up. Here's the list...
    Makes > 1996 BMW > M3 > Engine Parts, Seals > Block/Lower Engine Gasket Set
    Part Number
    Brand / Description
    Price
    List
    Core
    Qty
    Total
    11111740981
    VictorReinz
    Block/Lower Engine Gasket Set $65.93 $127.50 $65.93
    11241280582
    Glyco/Kolbenschmidt
    Connecting Rod Bearing Set; Standard $47.30 $168.00 $47.30
    11241739728
    BMW (OE)
    Connecting Rod Bolt; 44mm Length $7.62 $9.00 x12 = $91.44
    11129069861
    VictorReinz
    Cylinder Head Gasket Set $253.76 $400.75 $253.76
    11211706847
    Glyco/Kolbenschmidt
    Main Bearing Set; Standard $88.40 $217.99 $88.40
    11251405783
    Schoettle
    Piston Ring Set; Standard 86.415mm; 4 Rings per Cylinder $167.50 $610.50$167.50
    11311722651
    BMW (OE)
    Timing Chain Guide/Rail; Camshaft to Camshaft Chain $21.90 $26.30 $21.90
    11311703717
    BMW (OE)
    Timing Chain Guide/Rail; For Lower Timing Chain $62.90 $68.94 $62.90
    11311726480
    BMW (OE)
    Timing Chain Guide/Rail; Lower for Crankshaft to Exhaust Cam Chain $17.40 $20.16 $17.40
    Parts Total
    $816.53
    Grand Total = 816.53 + main bolts (haven't sourced yet) + c-clips that hold the wrist pins (also haven't sourced)
    All of this is through Arizona Autohaus. RealOEM has the rod bolts listed for $4.xx if I'm not mistaken, so I'm going to check dealer tomorrow on everything.
    Does anybody know of a cheaper source with same OEM quality brands? (or have a hookup for a fellow r3v'r :D)
    Thought I'd ask before I pull the trigger. Help a brother out ;)
  • Jean
    • 18228
    That's not too bad actually... check the price on the oil pumps (m5x/s5x or m30, yikes)
    • e30this
      • 3580
      yeah its a lot but in the end it is worth it.
      • Mastrcruse
        • Sep 2005
        • 5340
        I had the M30's top end rebuilt and all the gaskets replaced. I didn't do anything with the lower end (other then the gaskets) because then you really get into serious money. All in all I think I spent around 600-700 on it but it was definately worth it. Also when trying to sell it the buyer knows you didn't cut any corners.
        • e30serg
          • Dec 2006
          • 562
          I'm in the middle of rebuilding my whole s52, including the oil pump. I was able to get everything from pelicanparts.com, including the c-clips for the con-rods. You don't have to replace the main bolts. I even replaced all the timing gears, the oil pump gear and don't forget both tensioners. I don't know how many miles you had on there, but mine had 144k.
          Also, think about replacing all the little bolts (M6 or so) that hold the tensioners on. Also the two little torx screws that attach the front of the head to the top of the timing chain cover. I've heard horror stories of those snapping off.
          Do yourself a favor and get the special timing tools. Especially the camshaft holding tool. You can't just make the square ends on the cams sit flat. They are not that way when you use the holding tool. You'll see what I mean when you do it.
          I haven't had time to update it lately, but check it out:
          • e30serg
            • Dec 2006
            • 562
            One last thing-make sure you REALLY need to bore things out before you do it. I didn't have to. I just had the shop clean them up. My valve guides and springs where also good, so I left them alone. I am going for a good DD, not a track rat.
            • 318isbmw
              • Nov 2005
              • 2843
              800 isn't bad at all. While your there though, might as well bore it .030 to clean it all out and throw some pistons in. Seriously would suck to know that you didn't just go balls out and actually rebuild it while your there. Think those are bad, build up a FE ford motor. Was $2500 just for a stock rebuild on my dad's 390. That didn't include the labor to actually assemble the motor as we refuse to let anyone touch the final assembly.
              • FredK
                • 14762
                At Tischer BMW (www.getbmwparts.com), the OE parts are
                11241739728
                BMW (OE)
                Connecting Rod Bolt; 44mm Length $4.90 x 12 = $58.80
                11311703717
                BMW (OE)
                Timing Chain Guide/Rail; For Lower Timing Chain $43.06
                11311726480
                BMW (OE)
                Timing Chain Guide/Rail; Lower for Crankshaft to Exhaust Cam Chain $12.84
                07119934460
                Piston circlips, 12x$0.28 $3.36
                r3v member "blunt" sells OE BMW parts. If you PM him a list of the part numbers you need, he can get the parts quickly.
                • dude8383
                  • Jan 2005
                  • 10387
                  11241739728
                  BMW (OE)
                  11311703717
                  BMW (OE)
                  11311726480
                  BMW (OE)
                  07119934460
                  x2 on that, blunts rates are quite competitive.
                  • hugh jass
                    • 2220
                    that's pretty good pricing actually. try rebuilding an s38. it was 4k just to rebuild the head on my m5, and that was reusing 12 of the valves that were still good. timing components on the s38 are crazy expensive.
                    if you want another price, email blunt. he can get any oe part.
                    ______________________
                    ex-Chief Operating Officer
                    Blunt Tech Industries
                    West Coast and Pacific Rim
                    • madjurgen
                      • May 2005
                      • 1203
                      You think 800$ for a full teardown is expensive? :roll::roll:
                      As time went on, the factory developed the car each year, making it faster, more comfortable, and capable of handling at higher speeds.
                      You don’t want this. You want the trickiest, most dangerous, oldest model you can find. Only then can you prove to the world that you’re a man.
                      • e30polak
                        • 6136
                        X2 this is an m3 engine we're talking about, not a b16.
                        INSTAGRAM: @UNDR8D_EMPIRE
                        • Autobahn Sport
                          • Apr 2008
                          • 411
                          I was going to say, $800 sounds like a bargain. I think I would tip the delivery guy.
                          Autobahn Sport - ***503.715.0044*** - "ABS BMW Parts" on AIM
                          **To avoid delays with shipments, please note which parts you are paying for AND YOUR R3VLIMITED USERNAME in the "note to seller" field when using PayPal**
                          • MIKe30
                            • Sep 2006
                            • 2334
                            http://www.techiemechie.com/tmblog/
                            Thanks for the insight serg. I thought all OE bolts were torq once only? I'm going to replace the main bolts anyway, peace of mind. Oh, and mikey's (white325is) got some fresh bmw tools up in williamsport :nice:
                            Extra money isn't worth the gain IMO. Block's already been honed anyway, too late.
                            11241739728
                            BMW (OE)
                            11311703717
                            BMW (OE)
                            11311726480
                            BMW (OE)
                            07119934460
                            Thanks Fred. Good looks! Going to have to pass on the "blunt will get me cheap oe" parts though.
                            Yes, for just some bearings, bolts, and gaskets. Especially since it's not really a FULL teardown, more like a half teardown since it's only bottom end and the figure is parts only - labor is extra obviously.
                            It's not an m3 engine, it's a stroked 328 whether we like it or not.
                            • So Live
                              • 2512
                              Lol! Add up parts to build a forced induction motor and then lets talk. That $800 to have a fresh motor thatll be exactly what you want is not a whole lot of money.
                              That said, anybody know where to get an OE oil pump the cheapest?
                              Good luck with the build dude and youll sure be happy and your $800 will be an after thought when your spanking cars that cost a lot more than yours did.
                              -Chris
