I just aquired a Euro S50B30 and want to keep this pretty penny safe. where can i get an oil pan baffle for the E34 oil pan?
E34 oil pan baffles?
Tags: None
I had to cut mine out to fit the pan on.Comment
I would check ethier turner or bimmerworld. Call them dont look online.Comment
I apologize for the semi ignorant post then. I believe the e34 windage tray was welded or riveted in, from the pics I've seen, so I don't believe there is an option to go in the pan. Did the euro s50 pan have a tray in it? I'm suprised it wouldn't include one, with the performance it has. Does it have provisions for one, like threaded bolt holes? Is the block the same as an US s50? Would one from it fit? I know Isera-Johnson (sp?) makes bmw crank scrapers, but Idk if they make them for your engine. Other than that, I'm sure the big name tuners (VAC, Bimmerworld, Turner, etc.) make or know someone that makes one for that euro engine. Or try a Uk based bmw forum? I hope this is a much more helpful post.Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.Comment
with that said, i would say that the stock s52 windage tray is a much more effective design than the one rivited to the e34 pan.sigpic
Gigitty Gigitty!!!!
12 135i M sport cabrio grey/blackComment
The E34 pan was not designed up run on a S50 B32, so some things may need to be changed to get it to work. While having a windage tray might be helpful, I am pretty sure getting something to work would require a custom solution. I am jsut reporting what my data tells me and oil pressure doesn't seem to be a problem...so I haven't ever tried to weld up even a baffle.Comment
