No comp on cylinder 1... M50
  • e30this
    • 3580
    UPDATE!!!!
    Heres some photos of the problem..
    ok well. I dont know where to start or how to explain.
    I work out of town through the week and the wife decied she wanted to drive the car to work and to do some stuff. No big deal.
    She drives good and doesnt piss around. So I feel safe letting her drive.
    She called me up and said that the car was acting funny after she came out of the store.
    So I asked her what it was doing. She said when she would down shift or let off the gas to slow down it would backfire and she said when just driving down the road it sounds like a subaru.
    So I get home around 9:30 and decide to take the car for a ride.
    When I down shift or I let off the gas it back fires.
    If Im just cruzing through town it sounds like it is a subaru with with an aftermarket exhaust.
    So I get it back to the garage and I do a comp test.
    cylinder 1 doesnt read anything
    cylinder 2 is right around 105-110
    cylinder 3 is the same as 2
    cylinder 4 is the same as 2 and 3
    cylinder 5 is the same as 2, 3 and 4.
    cylinder 6 is right around 100
    I figure well great, something is fucked up.
    So I do a leakdown on cylinder number 1.
    I dont hear any air coming from the exhaust. I dont hear any air coming from the intake.
    So I figure the ring is fucked up. So I squirt some oil in the cylinder and hook up the comp test and still nothing.
    I dont have any coolant leaking into the oil, No foam and no milkyness.
    Sooo. Any one have any ideas??
    BTW the Motor is a M50 with M52 cam trays and lifters and S52 cams. TMS chip and 540 maf. Im running 92 oct.
  • golde30
    • 11464
    money shifted. ask me how i know....
    sounds like you have a whole row of bent valves...probably exhaust. when i money shifted (4th->3rd instead of 5th), i floated the valves on over-rev and since the exhaust valves are closer to the pistons, all 12 of them got bent. when i did a comp test, i got like 30-130-160-160-130-130 or something like that. after getting the head rebuilt i comped it again, and it was about 200 across all 6, for comparrison.
    IG: @Baye30
    • e30this
      • 3580
      I thought she might have did that and not said anything because she knows how Iam about letting people drive my car.
      Im anal about it. Maybe she will say something when I tell her whats wrong and how much its going to cost to fix.
      But I would have thought with the leak down test that I would have heard the air coming out of the exhaust. I was putting about 200 psi through that cylinder.
      • threlevenguy
        • Dec 2006
        • 1057
        No disrespect to her, but if it was her fault and you started going on about the cost of the fix, she would probably keep quiet haha. That's what my cheap ass would do.
        • e30s52
          • Oct 2007
          • 5235
          That really sucks if its a bent valve after all that work. But it does sounds like a bent valve.
          www.gutenparts.com
          • thereisnoyun
            • Feb 2007
            • 2301
            women will lie about something like this, even if its thier last breath. haha All you need to do, is see how much better she is trying to "treat you" and you'll know if she is guilty or not hahahaha.
            • e30this
              • 3580
              Yeah, Well we will see what the comps are tomorrow when the motor is cold. See what happens then.
              If I have to rip it out and rebuild the head Im going to do the bottom end at the same time.
              • Farbin Kaiber
                Lil' Puppet
                • 29502
                Originally posted by e30this
                Yeah, Well we will see what the comps are tomorrow...
                Sounds like your gonna need to be doing this with her for a time. I'd just hang my head in shame once in the presence of my SO if she did that. Then I wouldn't hold it over her head ever again, but use it silently to get a vortech supercharger.
                • euroshark
                  • Apr 2006
                  • 3491
                  money shifted.
                  That's how my first M90 was when I bought it... the head was totally fucked.
                  lol. Yeah, don't be hard on her... Just get yerself something nice to make up for it.
                  • MIKe30
                    • Sep 2006
                    • 2334
                    s52 time!!!
                    In all honesty shitty situation. But on the bright side you might as well pick up a blown s52 if you're going to rebuild the m50. It will cost you the same to rebuild, and you already have all your obd1 stuff and you'll have an extra set of cams. Or a set of cams if you just pick up an s52 block.
                    • e30this
                      • 3580
                      Well its confirmed its a blown head gasket. We put some more pressure into the number 1 cylinder and took off the rad cap and it was bubbling.
                      Sooo. Now Im weighing my options. Part out the M50 and build a stroked M20 like I had in my 4 door. or rebuild the m50 and add some more goodies.
                      • e30s52
                        • Oct 2007
                        • 5235
                        M50 with more goodies!
                        www.gutenparts.com
                        • e30this
                          • 3580
                          yeah thats what I was thinking.
                          What should I do though?? hi comp stroker or low comp supercharged?
                          I would rather stay NA
                          • e30s52
                            • Oct 2007
                            • 5235
                            Stroker 2.9? STU on here built his to a 2.9 I think and makes more then my s52 does.
                            www.gutenparts.com
                            • e30this
                              • 3580
                              You know the specs on it??
