(I searched and read) Booster & MC Recommendations for e36m3/ti brakes
  • M3forJTB
    • Nov 2008
    • 66
    Like the title says, I searched and read most of the threads relating to this aspect of the swap.
    However, it seems that there is limited info with regards to which booster/MC combo was used on this particular setup.
    I did find a few saying that they ran the 320i booster w/ 735i MC using the e36m3/ti brakes... problem is the results and criticisms were all a few years old, and I figured that there may be more feedback by now.
    Anyways, I plan on using my e36 M3 front brakes with e36 318ti rears. (OBD1 S52 swap; not that it matters)
    Which booster/MC combo would you reccommend and why? also what is the pedal feel, assist, and lockup like with each recommended combo/setup??
    TIA :)
  • Uber E30
    • 1409
    IX booster and any 25mm MC.
    -Alex
    • matt
      • 3732
      What he said.
      I've done it both ways (every way, actually) and I always prefer the iX booster and a big e34 M5 25mm master cylinder.
      • B3M2W5
        • 283
        Go with what matt said the IX booster is good easy and the M5 master cyl makes a hell of a diff or it did to me for the amount of pressure you put down.
        IX booster and M5 MC is the way to go.
        • M3forJTB
          • Nov 2008
          • 66
          Thanks guys!
          Hmm... my cost on a new e34 M5 MC and Tank is $360.
          I can't see finding one used though.
          • matt
            • 3732
            You cant use the e34 reservoir. You'll need to add a remote one mounted to the shock tower. Look at Jason's sometime, that's how to do it.
            • M3forJTB
              • Nov 2008
              • 66
              Thanks Matt!
              You coming to Sweetwater this evening?!
              • matt
                • 3732
                Planning on it. :)
                • M3forJTB
                  • Nov 2008
                  • 66
                  See you there!
                  (I'll try not to bore you with swap questions)
                  • etxxz
                    • Feb 2006
                    • 2085
                    recommended that either you take the restriction valve for the rear or put a bias valve on your front line otherwise you'll have waaay too much braking on the front. i have the same setup (s52 obd2; not that it matters) ; /3
                    iX / 735i booster with m50 5-series MC (same as iX and other 25mm MC's). willwood bias with bmw flares from IE opened 5.75/9turns.
                    No more e30s for me.
                    88 black BMW OBDII 332is dedicated track [sold]
                    88 BMW OBDII bronzit 332is [RIP 03/08]
                    91 BMW 325i [sold]
                    86 Corolla 'Ae86' HB 20v trd [sold]
                    http://youtube.com/watch?v=pTj7Hn9v5Rs
                    • M3forJTB
                      • Nov 2008
                      • 66
                      Thanks for the info!
                      Just to be sure, the iX and 735i boosters are the same? (the 735i should be a bit easier to source)
                      • etxxz
                        • Feb 2006
                        • 2085
                        they are ex for the piece that screws on in the back. from my junkyard hunting experience there were a couple more cars (5-series) with these boosters. i have a booster and MC in my garage right now (Fl too) pm me an offer. It was the one from my last (rip) e30 and now my second backup.
                        91 BMW 325i [sold]
                        • M3forJTB
                          • Nov 2008
                          • 66
                          Ygpm
                          • Mohammed_A
                            • 344
                            does anyone know if the ix/735 booster would work with a s50b32 with itbs? (euro motor)
                            • etxxz
                              • Feb 2006
                              • 2085
                              it will not. speak to (damn i forgot his r3vname again) search under brake booster euro motors there's a thread specifically for this.
                              91 BMW 325i [sold]
