S52 on Stock 413 DME
  • bostonbmw
    • Nov 2004
    • 429
    I am wondering if its okay to run a S52 on the stock 413 DME. Its out of a 325i so I dont know if it will be dangerously lean or something along those lines. I dont want to damage my motor but would like to delay the purchase of a chip if I can. Thanks Brian
  • e30this
    • 3580
    You can run the 413 if you swap the rest of your motor over to obd1
    • e30s52
      • Oct 2007
      • 5235
      I dont think it will run right though. I.e. running lean top end I think.
      www.gutenparts.com
      • lifeiskaos
        • 1709
        how about a stock 413 on an obd1 m52?
        you'll probably have better luck with the stock s50 obd1 ecu (506 i think??)
        • hoveringuy
          • Dec 2005
          • 2747
          I don't think there's much difference between the 413 and the 506.
          I would use the 413 and an appropriate chip. The extra displacement isn't a big deal because you have larger injectors to match, but the change in the cam is what throws it.
          • matt
            • 3732
            Only the chip is different between the 506 and the 413.
            Make sure your injectors and MAF match your chip. IE, use 17.5lb injectors if you're running a stock M50 or S50 chip.
            It's a dumb idea though. Sorry.
            • madjurgen
              • May 2005
              • 1203
              +1. Way to perpetuate the stereotype of r3v members being retardedly cheap. You can spend 2500$ on a motor but cant fork over 250$ for a chip?
              As time went on, the factory developed the car each year, making it faster, more comfortable, and capable of handling at higher speeds.
              You don’t want this. You want the trickiest, most dangerous, oldest model you can find. Only then can you prove to the world that you’re a man.
              • sushipower
                • Aug 2005
                • 156
                Where are you guys ordering your chip from?
                Thanks!
                • lifeiskaos
                  • 1709
                  ooops i asked about an s52 when i meant obd1 m52. fixed
                  get a chip from TRM
                  • rThor432
                    • Feb 2007
                    • 3907
                    I ran my S52 with a 413 for the past 4-5 months. No long driving periods. It just ran rich because I had the pink top injectors.
                    But I just got my TRM chip, so no more worries about my frankenstein setup running funky on the 413.
                    • loonibab325i
                      • Dec 2005
                      • 770
                      wtf? i thought you were supposed to run the 413 wehn converting to OBD 1... maybe thats why i have issues? i just run rich but i do have a TMS chip meant for my setup.
                      s52 0-150mph & more http://www.youtube.com/loonibab325i
                      • hoveringuy
                        • Dec 2005
                        • 2747
                        I'm running my M54 on OBD1 and the 413, using a Dinan S50 chip. It runs lean at the top but that's probably because it's kind of a non-standard setup.
                        Once I verify my fuel pressures are Ok I'll get a TRM M54 OBD1 chip.
                        The 413 is a good, versatile ECU.
                        • bostonbmw
                          • Nov 2004
                          • 429
                          Has anyone passed emissions on their S52 with a 413 DME ?
                          • rThor432
                            • Feb 2007
                            • 3907
                            If I had a cat I'd pass emissions... Do they test emissions on pre-96 model year vehicles in Virginia?
                            • bostonbmw
                              • Nov 2004
                              • 429
                              not in all county's but in mine they do
