M50 non vanos swap into 318
I guess I should clarify what I want to do. And let you guys tell me if it's possible.
I want to swap the M50 non vanos into a 91 318is using the 318 tranny and stock driveshaft. I don't care what clutch I have to use or if I have to get it machined. I also don't mind making a tranny cross member as long as thats all I have to do, I don't want to make a shift rod, but if I really have to I will.
Yes most of what you want to do will work.
But you WILL need to use an e30 M20 driveshaft and the associated shifter linkage will have to come from a 325 as well.
Done deal. Do it.Comment
Did you see what the guy in post#14 did to his M42 parts ?? He shortened them to work .
Use the parts i just listed and it all bolts up .
Quit asking questions already .Comment
CUSTOM!!!!! A member on here makes them.Comment
You can use the stock crossmember with the right combination of OE mounts or modify your existing crossmember or fab up a new one.
Heres a modified stock crossmember :
Easy to modify ....just shorten the one side and space up the other.
Same exact mod and angle that youd use with the Getrag 260 when combined with an M50.Comment
The 240 can use the stock 240 trans mount. I used a e36 drive shaft and shortened my 318is shifter linkage.www.classicdaily.net
1970 m42 swapped 2002
1985 LS1/T56 Swapped e28 (557e)
www.blunttech.com - For all your parts needs
Follow me on Instagram for constant build updates @classicdaily
https://www.facebook.com/ClassicDailyLLCComment
awesome thread... I'm trying to gather all the info for m50 non-vanos swap for my 318i. If its not asking to much, could you make a list of all parts and things needed, also specify which model it came from. I would really appreciate it. Good luck with your build..."i love vee tek, its a wonderful sound when you driving right by it"
If you bought anything from me, please leave a feedback here: http://www.r3vlimited.com/board/show...ghlight=drulleComment
