OBD1 s52+3.46 lsd+ZF 320 = OMFG!
  • e30polak
    • 6136
    Originally posted by loonibab325i
    man first gear and most of second gear is pretty much pointless with the 3.25 even with 235 rt-615 tires. how hard is it to get traction with the 3.46? And i know gearing doesn't "give you power" but does it speed up acceleration? what is the gears strong points?
    Anyway, glad you found a bad ass drivetrain setup.
    I don't really care about launching, that's pointless in a 24v e30. If I roll from 20 it's fine. I normally punch it in high first, then there is plenty of traction.
    Originally posted by mazur
    Can't be as good as my 2.93
    But I second the traction question. I can't hook 1st even if I roll the throttle in, and that's with 245/45/16 Z212's. They're probably heat cycled out, though :D
    I can't imagine a 2.93, even though the longer 1st and second would be fun. I did the 3.46 to have a shorter 3rd and 4th, and that's exactly what I got. Traction sucks balls even with the 3.25, I'm not drag racing here. The 3.46 is a very peppy daily gear! :-D
    INSTAGRAM: @UNDR8D_EMPIRE
    • FredK
      • 14763
      The shifting isn't all that bad, it's the tach out that sucks the most.
      let me simulate what it sounds like on the highway.
      BLEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEE EEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEE
      • Farbin Kaiber
        Lil' Puppet
        • 29502
        You forgot the noise the coils make over the expansion joints on our fair freeways.
        • kronus
          • Apr 2008
          • 13032
          Are those more of a *crunch* or a *boink*?
          cars beep boop
          • Farbin Kaiber
            Lil' Puppet
            • 29502
            Think creaky senior citizen patella.
            • kronus
              • Apr 2008
              • 13032
              Oh wow, that's even worse.
              Did it snow last night? There is something that looks suspiciously like snow on the tree outside my room.
              cars beep boop
              • Farbin Kaiber
                Lil' Puppet
                • 29502
                I think your contemporaries are playing with you. Think of your tree as "The Dome".
                • daniel
                  • 6703
                  i have a 3.25 now with the ZF and i want to go the other way, to a 2.93! i don't even drive on the highway all that much.
                  http://instagram.com/dslovn.drives
                  • rThor432
                    • Feb 2007
                    • 3907
                    I guess I havent driven mine hard enough to know yet, but so far I'm digging the OD Getrag box with the 2.93. It has loooooooooong legs.
                    I think bumping it up to a 3.46 might be nice, but while I'm doing primarily highway driving and hardly any track days, it doesnt matter much to me.
                    • golde30
                      • 11464
                      traction is really that much of a problem for you guys? hmm, s52 must put out alot more power then s50, i cant break my 235's loose unless i try.
                      IG: @Baye30
                      • Mr Two
                        • Jul 2008
                        • 590
                        I'm running a 260 getrag with a 3.73, I'm assuming 3.46 w/ ZF is shorter?
                        Traction isn't a problem for me either unless it would involve launching. I can floor it from a stop and not really lose traction, just a little spinning at the top of 1st.
                        Running 225's.
                        • e30polak
                          • 6136
                          If I drove more highway then I would've gone longer, but I now have a street demon! :twisted:
                          We have a little more torque, but I have to gas it up, or pin it from a dig to lose it. And I only have 215/45/17 bfg kdws?
                          • e30polak
                            • 6136
                            Running 225's.
                            Your gearing is closer to a ZF with a 3.25, a 260 with 4.10s is almost the same I believe.
                            • StreuB1
                              • Sep 2007
                              • 113
                              yeah 3.73 with a ZF
                              thing is im really used to it oddly enough. i had a civic si from 2000 till 2008 (original owner) and it has a close diff also. at 80mpg i was at 4600rpm.
                              as long as i can get rid of the drone ill be fine. and after the sweet resonator i saw at the performance show over the weekend....and that is coming in today. i think i wont have any. :D
                              I like to build things with metal n stuff
                              • rThor432
                                • Feb 2007
                                • 3907
                                ^^That's much worse than my 318is was with the 4.10.. "Worse" depends on how you look at it of course-- I do 97% of my driving on the highway.
