Busy with the s50 swap, gonna remove the viscus(spelling???)fan and replace them with 2 x 10 inch electric fans.
My understanding is the viscus is a clutch fan that only spins with purpose when the engine gets hot, What temp does the viscus start working and what temp switch should i use to emmulate the viscus with electric fan. I will also still have my aircon fan which uses the bmw switch on the side of the radiator( i think thats a 90deg switch).
gonna run a seperate temp switch in one of the coolant pipes, which would be the perfect pipe? lower or upper?
