Vibration in motor/drivetrain
  • logger
    • Mar 2007
    • 385
    Originally posted by gazellebeigem3
    oops, i guess i missed that. I suppose it could be harder mounts, but that usually isnt very violent
    Hmmm any other ideas then?
    sigpic I HATE SPEED BUMPS !!!!!
    • 1990m3
      • 1180
      did you tighten your motor mounts?
      I agree though, alu. tranny mounts are going to vibrate -- A LOT. Especially since you did not properly match them to the motor mounts. If you have rubber in the motor you should have rubber in the trans. Gotta keep the mounting bushings consistent
      • logger
        • Mar 2007
        • 385
        It was the aluminum trany mounts after I put the worn out old ones back on it fixed the vibration problem. FYI
        • e30s52
          • Oct 2007
          • 5235
          Glad you got it fixed. How does it run now?
          www.gutenparts.com
          • logger
            • Mar 2007
            • 385
            Sooo good!
            • JGood
              • Jan 2004
              • 7959
              What's your reasoning behind that?
              e30 restoration and V8 swap
              24 Hours of Lemons e30 build
