M50 refresh opinions
  • BenM
    • 2184
    In order to better match the awesome E36 M3 brake power and grip of 235/40/17s that I will have once I go 5-Lug, I have decided to do a budget refresh on the M50TU that I yanked out of my E34 Touring last fall.
    The motor itself has 187K on it, with all documented oil changes at every 5K miles since new. The motor ran great on the 120 mile drive back from Rhode Island, with the only issue being a slight stumble when taking off, and the check engine light popping on and throwing the vacuum leak code.
    Anyways, instead of spending money on an S50, I figured I could do a decent job on this motor for not much $$, and just upgrade to a low mileage S50 at a later point. Just picked up some S50 Cams for it, and plan on doing all the usual bolt-ons too (3.5" HFM, 21.5lb. Injectors, 8.5lb. flywheel). Here is what I have in mind so far:
    - Headgasket and associated gaskets (Oil Pan, Valve Cover, Spark Plug, Timing Chain Covers, etc.)
    - New Head bolts (obviously)
    - Later style S50 conical valve springs and retainers (to go with the S50 cams)
    - Cylinder head cleaned and reassembled
    - Timing chain tensioner
    - Loctite on Oil pump nut
    Anything else I may be forgetting?
    Thanks for any advice/comments/suggestions.
    Ben
    Originally posted by BillBrasky
    E36's are the Stephen Baldwin of the 3 series family. They barely hold everything together and they only sold a lot because of the popularity of their older sibling.
    1991 318i Alpine II - S50/5-lug swapped - track car
    1989 325i Cirrusblau - Daily
    1970 2500 - Malaga over Grey Cloth
    2012 F350 6.7PSD
  • hoveringuy
    • Dec 2005
    • 2722
    -VANOS seals
    -O-rings on the oil filter housing plugs
    The last S50 was produced over 10 years ago. Are there still low mileage examples?
    • Uber E30
      • 1409
      Exhaust Manifold Gasket; At Cylinder Head
      11611717259
      Intake Manifold Gasket; Intake Manifold to Cylinder Head
      11421719855
      Oil Filter Gasket; Oil Filter Housing to Block
      11421730389
      Oil Filter Kit
      12611277129
      Oil Level Sender Gasket; O-Ring
      11131437237
      Oil Pan Gasket; Rubber/Metal
      035121119
      Thermostat Gasket/Seal; 60x3.5mm
      11531740437
      Thermostat Gasket/Seal; For Thermostat Housing
      11531722531
      Thermostat Housing/Water Outlet; Aluminum Update Replacement
      11531712043
      Thermostat; 92 Degree C; With Gasket
      11141720639
      Timing Cover Gasket; Lower Left
      11141720638
      Timing Cover Gasket; Lower Right
      11121738701
      Valve Cover Gasket
      11121735721
      Valve Cover Gasket; Spark Plug Hole Gasket
      11511711484
      Water Pump Gasket; O-Ring
      11721437202
      7mm Lock Nut; Exhaust Manifold to Head
      -Alex
      • BenM
        • 2184
        Originally posted by hoveringuy
        -VANOS seals
        Good call on the VANOS seals. Completely forgot about those.
        As far as S50s go, I guess I meant a lower mileage example would do. Something with around 100K, give or take a few miles would sound about right.
        Originally posted by Uber E30
        <snip>
        Thanks for the part numbers, but I plan on doing all those things anyway. They are included with the Engine gasket set available at BMAparts, Autohas, etc. Thanks anyways.
        Keep the suggestions coming.
        2012 F350 6.7PSD
        • alexbaby88
          • 219
          Might as well do a stroker conversion while you have the engine open.
          • jrdeamicis
            • Nov 2008
            • 956
            I would just order a top and bottom end gasket set. Oil pump, primary timing, and secondary timing chain.
            The top and bottom end gasket sets will have everything you need.
            Past Car : E30 S50 6 Speed 5 Lug 3.73
            Current : Z3 S50 OBD2 (Smog Legal) 6 Speed BBS RN Dual Ear Diff
            ___________________________________________
            BNB Designs
            Engine Swaps, Fabrication, Innovation, General Repair
            Richmond CA
            Julian 848-248-8029
            • Danny
              • 14216
              Think about turbo?
              • BenM
                • 2184
                Ok, thanks again Stephen (hoveringguy) for the VANOS Seals. They will be going to good use.
                So anyways, my dad decided he wanted to use the motor I was going to use, so I just went out and bought a wrecked '93 325is w/ 100K and most of the accessories. Not going to be doing the headgasket, but most of the other seals will be replaced.
                However, I did recieve a seized '99 328i Shortblock (Alumninum block M52TU) with an enormous hole where the con rod #1 went through. #1 piston was cracked into many pieces, #4 con rod was bent as well, and the block is unusable. The crank is perfectly fine though, so I am in the process of sourcing a set of good M52 rods and pistons to match the crank, and then to put them together in the iron block'd M50TU.
                Out of curiosity, does anyone know what sort of compression ratio an M52 crank w/ s50 pistons (86.1mm Bore) and S50 rods (135mm Length) would produce? I am thinking somwhere around 9-9.5:1 due to the reduced crank stroke, creating more piston clearance to valves. Can anyone confirm?
                Thanks.
                2012 F350 6.7PSD
                • PiercedE30
                  • Apr 2005
                  • 4220
                  #2 Non-return valve - PN: 11 12 1 735 180
                  From when I was working in a shop, that was the main issue that we found to cause lifter bleed down and premature lifter failure. Most of the ones that you will find, the spring has worn and no longer has the tension that is needed, or the ball has worn enough to allow oil to bleed past it.
                  My 2.9L Build!
                  • jrdeamicis
                    • Nov 2008
                    • 956
                    Just order a top end and bottom end gasket set and be done with it. Has everything you need for the most part include valve stem seals. Just make sure to get an Elring gasket set.
                    BNB Designs
                    Richmond CA
                    Julian 848-248-8029
                    • e30this
                      • 3580
                      What about a Dr. Vanos stage 2 unit? I have heard some good things about them puppys and the price isnt all that bad.
                      In my M50 I ran M52 cam trays, listers and S52 cams, 21.5 pink tops, euro maf and TMS chip. I loved every minute of it till I blew a whole in the piston. :)
                      • StereoInstaller1
                        GAS
                        • 22679
                        The M/S 5* motors are a bit heavier than the stock M20.
                        In order to correct your weight balance, you should add a subwoofer.
                        Oddly enough, I know a great source for these.
                        Closing SOON!
                        Thanks for 10 years of fun!
                        • BenM
                          • 2184
                          Lol right on man. Unfortunately, audio equipment will be at a minimal for this car ('91 318i 4dr.) since I will be tracking it and am already planning on getting the coilovers corner-weighted.
                          I am however interested in one for my other E30!
                          2012 F350 6.7PSD
                          • jrdeamicis
                            • Nov 2008
                            • 956
                            The Dr. vanos stg 2 is really the only way to go. The stock stuff gets all bound up and does not transition nicely when advancing the cam. I have a Dr. Vanos stg 2 and its fantastic and I would not even think of just replacing the vanos after seeing what stock spring washers and washers look like.
                            BNB Designs
                            Richmond CA
                            Julian 848-248-8029
