I apologize if this has been beaten to death previously, I STFA and didn't find much.
I have what the PO told me is a M50 out of a 1995 325, so I assume a M50B25. I want to get a little more out of it and was thinking of going with S50/S52 cams, pink tops and 540 MAF.
From STFA it apears I can use S52 cams as long as I use S52 trays and lifters...is this correct? Or would I be better off just using S50 cams? Do I need anything else from the S52?
Is there a difference between the S50 and S52 cams from a performance standpoint in the M50?
I apologize again if this has be previously discussed, I'm a E30 noob.
Thanks!
Thanks!
