I built my adapter for my car using the wiring diagram for my year. I am using the old style connector.
The key will spin the motor, but not turn the fuel pump on. The fuel pump will turn on if I jump the FUEL PUMP wire to B+.
My wiring diagram runs like this using the old style connector w/ wiring for a 84 325e and an S50.
E30 Side / Engine Side
Alternator Charge / 1 - 25
Coolant Temp Sensor / 4 - 12
Electric Fuel Pump / 7 - 13
Power Supply with Ignition / 10 - 21
Oil Pressure / 16 - 23
Service Indicator Reset / 17 - 19
So the oil pressure works, alternator, and it cranks.
But it will not turn on the fuel pump, and I do not hear the main relay when I turn the key to the on position.
The computer was warm after sitting for an hour while I was diagnosing some stuff.
What do you guys use the power with ignition turned on fuse protection for?
I was able to get the computer to throw a CEL with a Ohm meter but now it doesn't want to do that I and I am afraid.
