So who kept AC
  • 416stroker
    • May 2008
    • 2448
    So who kept AC
    What did you guys do for lines. Im trying to get custom lines made But I need to find the ends for the Compressor, does anyone know where I can just find those? I cant see paying 249 for a set of lines.
    84 318I Delphin RIP
    87 325IS delphin 24v Sold
    89 325 Alpineweiss
  • hoveringuy
    • Dec 2005
    • 2687
    I got my parts from ACKITS.com and had the fittings pressed at a local A/C shop for $20. I haven't bothered to put it back on since the M54 swap, it's nice even for the mild Seattle summers.
    • 416stroker
      • May 2008
      • 2448
      I dont see the retarded fittings on there site.
      84 318I Delphin RIP
      89 325 Alpineweiss
      • Drew325is
        • Oct 2004
        • 520
        The fittings you're after are called "pad" fittings...I found this to be a solution:
        • dude8383
          • Jan 2005
          • 10387
          http://www.r3vlimited.com/board/show...7&postcount=22
          what are "pad" fittings? are you cutting that line to get the fitting?
          sorry not much of an expert with a/c lingo.
          • Drew325is
            • Oct 2004
            • 520
            Pad fittings are the figure 8 style fittings on each end of the hose...it's just a generic term for them:
            I couldn't find anything suitable aftermarket, so the above hose was used as a donor for the fittings.
            From memory, orca and the like suggest buying a pair of E36 hoses to get the fittings.
            • dude8383
              • Jan 2005
              • 10387
              thanks for clearing that up!
