Mounting IX booster right to firewall and master cylinder question
So if you take the adapter plate off the booster. Cut out the center section and weld the two plates together and to the booster you can fit a finger between the manifold and the booster and the rod works great.
Past Car : E30 S50 6 Speed 5 Lug 3.73
Current : Z3 S50 OBD2 (Smog Legal) 6 Speed BBS RN Dual Ear Diff
___________________________________________ BNB Designs
Engine Swaps, Fabrication, Innovation, General Repair
Richmond CA
Julian 848-248-8029
So what did you do here? Cut that spacer plate and weld in back together without the space? Pictures?
took bracket off.
drilled two of the mounting holes in the firewall to make them bigger. (will only use two bolts to mount booster)
cut and thread the rod since it will be too long for the brake pedal now.
done.
No more e30s for me.
88 black BMW OBDII 332is dedicated track [sold]
88 BMW OBDII bronzit 332is [RIP 03/08]
91 BMW 325i [sold]
86 Corolla 'Ae86' HB 20v trd [sold] http://youtube.com/watch?v=pTj7Hn9v5Rs
By the way guys e36 masters fit, I think 325i's have 23ish mm masters and M3's have 25-26mm, with the 96-99 m3's having the biggest of the bunch. realoem tells you the bore size when you look it up, too late and I'm too sleepy, but I love my IX booster installed with factory spacer thing, 98 m3 master and e36 m3 front brakes.
Mossman, did you have any clearance issues with the resevoir/intake tubing?
Did you guys cut/thread the rod at home?? I've taken it to a parts guy, and machine shop - they both make it out to be a big deal since it's attached to the booster. They want to use a lathe.
1, there is no easy way to remove the rod correct? (I tried to remove the one on my 325is booster to see if I could swap the rods instead of shortening the ix, but that didnt go so smooth)
2, What exactly did you do/use to shorten yours since the base of the rod is so much thicker than the upper part that's threaded?
Hope this can be done at home.. really want this car running tonight/tomorrow!!
