Mounting IX booster right to firewall and master cylinder question
  • Dominic49
    • Feb 2007
    • 1373
    #31
    just thread it once in a plus 1 size and then thread it with the final size just as you would with the e21 booster
    • jrdeamicis
      • Nov 2008
      • 956
      #32
      I did mine at home. But I cut off the smaller top section and threaded the lower half to m12x1.5 an drilled and threaded the fork to the same. Works great.
      If you want to do it the way I did mine I will rent you the die and tap.
      As far as the booster that people had questions of.
      Take your spacer plate and cut out tubular center section so you have the 2 stud side and the 4 stud side with nothing in between. Then you grind down the studs ( 2 side) and stud weld the first plate to the booster. Then you weld the 4 bolt section to the 2 bolt section that is on the booster. Voilà.
      Be careful or you will ruin your booster. S
      Past Car : E30 S50 6 Speed 5 Lug 3.73
      Current : Z3 S50 OBD2 (Smog Legal) 6 Speed BBS RN Dual Ear Diff
      ___________________________________________
      BNB Designs
      Engine Swaps, Fabrication, Innovation, General Repair
      Richmond CA
      Julian 848-248-8029
      • MIKe30
        • Sep 2006
        • 2334
        #33
        i took back the rethreader I rented from autozone, and asked them if they would rent out a tap and die set. They didn't.
        BUT, turns out they are not ~$200 like I was told by somebody - they're only ~$20 and they had one last metric set left. It's downstairs waiting for me to get back to work!! :)
        • surebimmer
          • Jan 2004
          • 978
          #34
          Nice. i ground down my on a grinder and then threaded it.
          • MIKe30
            • Sep 2006
            • 2334
            #35
            My booster rod is in bad shape. Think I'm going to go the cut/weld route. Anybody feel that is a bad idea?
            With the above suggestion of +1 size thread first, then 10mm thread - I tried it. Had to grind the rod a bit to get the 12mm on there. Thread it down (unfortunately the threading was a little lopsided)
            Then tried to thread with the 10mm, and no bueno. Had to grind the 12mm threading just to get the 10 started. My cheap $20 tap/die set wasn't what it was cracked up to be and stripped, and now the rod threading is fubar'd at the bottom.
            I cut the good thread off the top, hoping I can find someone tomorrow with a welder to cut 2 inches off the bottom half and weld my good 10mm threads on there.
            I could very well be driving my car right now had this booster not been an issue.
            • jrdeamicis
              • Nov 2008
              • 956
              #36
              Well my booster decided life was too hard at the auto-x.
              BNB Designs
              Richmond CA
              Julian 848-248-8029
              • Spaz
                Crazy Canuck
                • 2276
                #37
                deamn decent damage you did there :p
                Cam .W '91 325is
                Spaz's 1991 Alpine White???? S52 Build Thread...
                • jrdeamicis
                  • Nov 2008
                  • 956
                  #38
                  It works great as a fruit basket now.
                  BNB Designs
                  Richmond CA
                  Julian 848-248-8029
                  • fronton
                    • Oct 2009
                    • 1262
                    #39
                    reviving and old thread to ask if anyone is running the e32 booster with an iX or other MC? Anyone know if the e32 booster is any larger or smaller than the iX booster? My iX booster/iXMC just died and I'm trying to do something other than another iX booster.
                    • fronton
                      • Oct 2009
                      • 1262
                      #40
                      Just so everyone knows, the e32 735i double booster system is NOT identical to the iX booster despite common opinion. The vacuum hole on the e32 is on the passenger side of the MC whereas it is on the driver side of the iX booster. Also, the metal mounting bracket for the iX is 6mm shorter than the cast aluminum bracket of the e32 which can make or brake really tight fitment issues.
                      Also, the e32's push rod is longer and has a different, longer clevis. They do bolt up the same other than the e32 sticking out a little further both into the brake petal and into the engine bay, and MCs are interchangeable. The mounting brackets are interchangeable but the e32 has a different breathing and rubber backing design so when swapping the iX bracket onto the e32 booster you must use the iX rubber boot.
                      Diameter and thickness of the booster itself is the same, just not the mounting bracket and push rod.
                      In order to fit the e32 booster in my e30 I had to swap the iX MC, metal mounting bracket, clevis, and dust shield rubber boot over. Not a big deal but you'll have to have an iX unit to strip part off of so you might as well use the iX booster. Mine was dead.
                      • übersteuern
                        • 45
                        #41
                        Second thread revival...
                        So if you mount the E32 setup without the firewall spacer, does the reservoir clear the intake boot or is a remote reservoir still needed?
                        If there's a reservoir which fits, has anyone got a part number for it please? (the huge-ass E32 reservoir doesn't fit with the intake boot)
                        Thanks
                        • Gooch
                          • Dec 2006
                          • 1674
                          #42
                          The iX master and reservoir will clear the intake boot with the booster mounted straight to the firewall.
                          '91 318is - OBD-II S52 swapped - E30 M3 5-lug - 5x120 BBS RC090 (E39 Style 5) - TCK D/A coilovers 550/700 [SOLD]
                          '87 535i - Vacuum brake conversion [SOLD]
                          '93 525iT - 5-speed swap - 320k and counting
                          '09 328xi - 6-speed
                          • Roysneon
                            • 4505
                            #43
                            Thanks
                            This is exactly what I have on my car. E32 booster, tapped and cut pushrod, no spacer, slotted firewall holes, mounted with 2 bolts. Clears the intake boot by a few mm, no real risk of it interfering.
                            Apparently the e34 540/530 remote mounted booster is the same diameter/depth, etc. as the 735 but the pushrod is already short enough as it doesn't use a spacer like the ix/7 series does. That's just what I've been told though, I haven't tried it out myself although the diagram on realoem seems to support it.
                            Originally posted by mbonanni
                            I am a pursit now.
                            • 2mAn
                              Señior Mod
                              • 21017
                              #44
                              how much are you guys cutting off the pushrod? I got my iX booster without the spacer so I cant reference how much space I need to trim off. The pic only looks like an inch or so
                              Simon
                              Current Cars:
                              -1966 Blue Boat
                              -1969 Red VW
                              -1986 White BMW
                              -2006 Green Thing
                              Make R3V Great Again -2020
                              • brent5631
                                • Jun 2012
                                • 421
                                #45
                                Yeah about an inch.
