Dual mass Flywheel compatability with M50 swap
  • e30strokr
    • 211
    Hi
    I been lurking thru the M50 swap threads (yes I read all 90+ pages) and I have not seen if the dual mass flywheel will/will not work on a M50 swap using the E30 G260 from my SETA which has a dual mass flywheel.. all the talk is about resurfacing the "I" Flywheel, is there a definite yes or no?!? got 2-3 items left to do and the clutch is a big one for me right now....
    thank for any helps or tips...
  • e30strokr
    • 211
    bueller?!?
    • bradmer
      • May 2016
      • 362
      Originally posted by e30strokr
      Hi
      Post #3 in the link below, good luck.
      Searched google for - R3V / M50 DUAL MASS G260 and found the link.
      • e30strokr
        • 211
        SWEET so I can use the stock e30 DM flywheel with the M50 clutch...
        heres the explanation in case link dies
        Credit WANGANSTYLE
        10-27-2011, 08:51 AM
        stock 240mm dual mass M50 family clutch.
        if your friend owns a e46m3 / e36m3 (dual mass 240mm)
        OR
        e28m5 / e34 m5 (single mass 240mm)
        and replaced its clutch with something cool you can put the stock clutch set into your e30. works great no joke
        S38/M30 240mm single mass clutch (e24/e28/34) M spec. the complete flywheel+friction disc+pressure plate just fits into a G260. I test fitted this myself last week.
        Stack height is also same between G260 original clutch, S52 clutch with DM fly, s38/m30 single mass. splines @ transmission are identical between a G260, Zfsg320, G265-6 or G280-5.
        both will handle 350 hp/lb-ft + in original factory form, AND plug and play with G260.
        Both will require you use a 24v starter, but you will need to do that regardless as you are installing a 24v engine.
        The USA specific S52b32 version has the lightest dual mass 240mm flywheel at ~22lbs.
        s50b30's and m50b25 nonvanos usually have a ~ 30 lb flywheel
        dual mass flywheels are wear items......so check the condition before you assume a used one is good. or order a brand new unit.
        240mm dual mass was used stateside in:
        m50 nonvanos 525i 1991-1992 (weaker clamping pressure plate than M3 obviously)
        s50b30 1995 m3
        s52b32 1996-1999 m3
        m54b30 330i e46 5 speed (weaker clamping pressure plate than M3 obviously, new style SAC self adjusting)
        m52b28 528i e39 5 speed (weaker clamping pressure plate than M3 obviously, new style SAC self adjusting)
        s54b32: giant inside spline for Getrag sg420 6 speed, but 240mm pressure plate and dual mass flywheel will plug and play into a G260 with S52 pressure plate.
        euro:
        s50b30 euro e36 M3 *286hp
        s50b32 euro e36m3 *316bhp - uk version is weaker than germany 321hp*
        If high torque use is of concern S50/s52 pressure plate and friction disc. they are the highest rated items, I have personally used successfully with S54b32 (343hp).
        Daily driver ok. fit is Plug and play into a G260. works with M20 also lol
