chip install
  • bmws50b30
    • Aug 2005
    • 1151
    chip install
    yes i searched.nothing came up or i'm blind.
    anyway, is the chip install directional? there's an arrow on the turner chip but not sure which way to install. thanks
    1991 330is
  • hoveringuy
    • Dec 2005
    • 2744
    Arrow corresponds to the notch you will see at one end of the socket it fits in.
    • bmws50b30
      • Aug 2005
      • 1151
      thanks!
      now, the car won't start. i hooked up the 3.5hfm and installed the chip. i know my engine is late 95 and i have silver 413. how can you tell if my 413 had ews? here's the spec for the chip.
      - 413 DME
      - 3.5" HFM - Bosch 800 Unit
      - 17.5# injectors
      - EWS-II
      - S50 Motor
      waht else can i check? could it be my hfm? the engine only cranks.
      1991 330is
      • bmws50b30
        • Aug 2005
        • 1151
        update...i swapped my stock red 413 and the car started with the 3.5hfm installed.
        here's what's on my silver 413
        WBSBF9321SEH05819, is this the VIN?
        1991 330is
        • BenM
          • 2184
          It's because you have a chip designated for the Silver Label 413 ECU (EWS). You need the chip designed for the 506 ECU (can be used in a 413 ECU w/out problems) or the same thing but stating that you want to delete EWS.
          Hope this makes sense.
          Originally posted by BillBrasky
          E36's are the Stephen Baldwin of the 3 series family. They barely hold everything together and they only sold a lot because of the popularity of their older sibling.
          1991 318i Alpine II - S50/5-lug swapped - track car
          1989 325i Cirrusblau - Daily
          1970 2500 - Malaga over Grey Cloth
          2012 F350 6.7PSD
          • bmws50b30
            • Aug 2005
            • 1151
            i know the chip is for silver 413 with ews. i'm assuming my 413 had ews and it should work. i got the chip really cheap that's why i tried it.
            my problem is determining what kind of silver 413 do i have and why the chip is not working. if it doesn't work i'll just sell the chip.
            1991 330is
            • BenM
              • 2184
              What I am trying to say is that the silver-label 413 will not work in an E30 unless the chip is stated to have EWS-delete. Pretty sure just because it had it before, doesn't mean that it should work now.
              What ECU/Chip combo have you been running? How was the car wired? Perhaps someone who has successfully wired/used an OBD-I S50 w/ EWS can chime in.
              2012 F350 6.7PSD
