Cooling
  • Mohammed_A
    • 344
    Cooling
    Some help please guys....
    im using 2 x 10inch electric fans mounted onto the radiator to cool my s50, the fans are switched on by means of a 82deg temp switch however this setup doesnt seem to keep the motor cool, the fans stay on for long periods but the temp gauge still passes the half mark.. any ideas?
  • Liam
    • 753
    Where is the temp switch located?
    How are the fans oriented and how many CFM do they push or pull?
    I'm Not Right in the Head | Random Rants and other Nonsense1st Order Logic Failure: Association fallacy, this type of fallacy can be expressed as (∃x ∈ S : φ(x)) → (∀x ∈ S : φ(x)), meaning "if there exists any x in the set S so that a property φ is true for x, then for all x in S the property φ must be true".
    • Mohammed_A
      • 344
      the temp switch is located on the top pipe from the thermostat housing into the radiator( check pic)
      Not sure about the CFM(???)
      • Liam
        • 753
        Hard to tell from this shot but it may be that the fans are restricted by a lack of room for the air to escape behind them?
        Could be a coolant bleeding issue as well?
        Not the cause I'm sure but the switch should be located on the cool side of the radiator (original spot).
        One other question (off the subject a bit, only curios) is that an e30 m20 radiator?
        • Mohammed_A
          • 344
          There is not much space at all....
          gonna bleed it again tonight, maybe im doing it wrong, with the m20 we had a bleed screw on the thermostat housing, how should i bleed the s50???
          yes it is a m20 radiator, why?
          • jrdeamicis
            • Nov 2008
            • 956
            Why dont you try using the temp sensor that is in the side of the rad.
            Past Car : E30 S50 6 Speed 5 Lug 3.73
            Current : Z3 S50 OBD2 (Smog Legal) 6 Speed BBS RN Dual Ear Diff
            ___________________________________________
            BNB Designs
            Engine Swaps, Fabrication, Innovation, General Repair
            Richmond CA
            Julian 848-248-8029
            • Mohammed_A
              • 344
              the temp sensor on the side of the rad is a 90 deg switch,will come on a bit too late ....
              • Mohammed_A
                • 344
                the sensor on the rad side is a 90deg switch, will switch on too late...
