24v swap using the G260
  • amcp
    • 489
    What is everyone using as the shift lever carrier? With the 10-15 degree tilt the oem e30 325 carrier does not have the correct angle to put the shift lever through the hole in the chassis. I cant find answers. Can anyone help?
  • reelizmpro
    • 9543
    I'm guessing they modify the carrier to compensate for that tilt in addition to the "twisted" DSSR or modified stock selector arm.
    88 M3 - LACHSSILBER
    89 M3 - ALPINEWEISS II
    • amcp
      • 489
      That was my guess too but there's not much to use as an example. Heat and twist? Its a cast aluminum piece, cant imagine it twists very well.
      • reelizmpro
        • 9543
        More like cut and weld.
        88 M3 - LACHSSILBER
        • bradmer
          • May 2016
          • 362
          I used a vice with a socket to bend the stock z3m shifter, going slowly it worked fine.
          • amcp
            • 489
            Both of these should get me the angle I need. Thank you both!
            • reelizmpro
              • 9543
              Z3M shifter has a lot of room under the pivot ball for that type of modification. Other levers typically don't have much room. I think it's better to mod the carrier than the lever. That way, you can resell or change shiftlevers as you please without having to modify them each time.
              88 M3 - LACHSSILBER
