I have a 88 vert that previously had a m52 in It.
Just swapped a 98 s52 motor with m50 intake manifold and obd1 harness, I swapped all for obd1 configuration. Car cranks but no fuel or spark...
-fuel pump works I tested It
-replaced main relay & fuel pump relay
-I have voltage going to the relays
-cps is reading .550
-ICV has constant voltage when key is off and has a humming sound.
-Tried swapping to another red label 413 but same symptoms
