Need info on m54 swap (using orig ECU)
  • Gruelius
    • Oct 2009
    • 298
    Hey all,
    A mate is about to swap a m54b30 in but wants to keep the ms43 or 45 management, can it be done?
    Hes happy to have the ecu flashed for EWS delete but are there any other inputs the ecu needs and will winge about?
    i figure
    pedalbox + sensors on the pedalbox for drive by wire
    Chassis harness connector and all other chassis side plugs the ecu harness goes into
    Cluster (most likely wont be used but is it needed for the car to run?)
    ews
    ews harness
    keys
    ignition module for ews
    any other info would be great
    and if you know of a place where we can send the ecu to be flashed to fuck off any other requirements (i.e. ews or can stuff) let us know
    we are not really interested in running m50 managment with the seatle circuits vanos board as it becomes quiet costly, due to us needing to purchase another whole motor just to get those bits (no m50's at yards). We also understand flashing the stuff out could cost quite a bit but would be worth it.
    going into a 88 325is
    thanks
    RIP 84 323i coupe 5spd w/ 14psi
    89' 318i
  • metris228
    • 11
    bump
    I am also very interested in this!
    Does anyone have any info?
    • hoveringuy
      • Dec 2005
      • 2749
      There's a third option you should consider.
      • Roysneon
        • 4505
        Market Motorworks has told me they are able to reflash the ECU, so the EWS parts (harness, ignition, keys....) are not necessary. As far as I can see this is how many S54 swaps are done, so it does happen. As for the cost of the reflash; I haven't gotten that far as I'm still working on getting my M54B30, I'm also not interested in running it OBDI.
        Originally posted by mbonanni
        I am a pursit now.
        • justice101
          • 36
          OBDI is for nubs
          • Elysian
            • 674
            Megasquirt FTW.
