My s54 touring!!!!!!!!!!!!!!!
  • White325is
    • Oct 2006
    • 5947
    #91
    Why do you keep avoiding the questions of wiring and where to get the ECU flashed, but PMing other people the info? Is it that hard to just post it here on the forums for everyone to see? I thought we was here to help each other out, not share info with some people and not others.
    Just sayin.
    • e30 fa life
      • Sep 2009
      • 197
      #92
      Originally posted by e30_neverstock
      :)that is epic! congrats.
      thanx............
      • jahnaboi
        • Oct 2006
        • 1742
        #93
        Just sayin.
        PM with your concerns when you get replied then post it up. lol
        SINdelle:E36 M3 5-Lug | 17x8 & 17x9 BBS RS | S52/ZF | 2.93LSD/3.5HFM/24lb Injectors/C&S Chip[B]SOLD[B]
          • 34830
          #94
          Just sayin.
          Who cares? If you really want to do the swap, it only takes a moderate effort to search for the info.
          • catuned
            • Jun 2011
            • 2324
            #95
            I like this a lot! :)
            For everyone asking how its done and all the info. If I did these swaps for a living I wouldn't just give the info out for free. I think e30 fa life is doing it for $$$ and as well as he should. Economy where it is everyone has to make $. Simple fact of life! Im with you e30 fa life. Im all for sharing and if e30 fa life is willing then he will. Until then do research and ask ask ask. :)
            Work We Do
            CAtuned Feedback Page|FB CAtuned Page
            http://www.catuned.com
            • sticksdaman
              • Apr 2005
              • 2987
              #96
              Glad to see someone else doing this, the more the better!
              Any shots of the oilpan/subframe? Im curious.
              Originally posted by ebelements
              Also, for those who don't know, negative camber is the greatest thing since sliced bread(panera). Even tire wear is for city busses and the elderly.
              • OBryan562
                • Jul 2011
                • 527
                #97
                cute girl! i didn't even pay attention to the other photos
                • e30 fa life
                  • Sep 2009
                  • 197
                  #98
                  thank you......i figured someone would understand.............
                  did not want to get into those famous r3v bashing matches .....just wanted to show what i did...and that it can be done ....and hopefully inspired at least one person to do it
                  • e30 fa life
                    • Sep 2009
                    • 197
                    #99
                    stock subframe...............same oil pan as all other swaps(M50,S50...etc)
                    • drutt23
                      • Feb 2011
                      • 392
                      #100
                      Car looks awesome overall. S54 is the tits for sure. The eyebrow looks pretty good too and I've been up in the air about that look for quite awhile now. Some pull it off, some don't. I do think that the mt2 pieces need to be straightened out a bit. They are a little out of whack, but nothing that can't be fixed.
                      Am I going blind and crazy, or are those foose wheels?????
                      1989 325i|1992 325i|And completely obsessed|:woowoo:
                      sigpic BMW. The Ultimate Driving Machine.
                      The Build...
                      • catuned
                        • Jun 2011
                        • 2324
                        #101
                        you sir have a PM
                        Work We Do
                        • Wanganstyle
                          • 2828
                          #102
                          Just sayin.
                          I think those hounding the OP's good work need to do some deep SEARCH. Good job OP for not handing out the obvious. OP is actually protecting many from giant electrical fires and burning their e30's by NOT posting diagrams or wiring specifics.
                          all you need to do to install a hacked OEM S54 ecu or aftermarket DME S54 is to ................ WIRE it.
                          get the diagrams+ pin outs of chassis and wire it. if you are not good at internet search, go to your local BMW dealership.
                          when I did this (s54 swap) in early 2010 I found the entire wiring manual for s54 online and printed it, then labeled everything and wired it. done done done.
                          I could have opted for a hacked OEM DME at the time for a price, but choose to use a full standalone as I enjoy having complete control of my dual vanos mapping :D.......not recommended for all.
                          One could easily send your harness to MMW or OP or others and have them do it for you. harness is harness is harness. Even making a harness 100% from scratch is not that difficult; you just need to know what you are doing. Not for noobs!!!
                          E throttle carry over items can be Z3 late model (m54)
                          DME flashing is done by more than a few. With the stock DME flashed/hacked, S54 installation is just like wiring in a S52 OBD2. DONE DONE DONE.
                          E throttle installation on cable throttle cars has been done on subaru's for a LONG time now. reference a 2006 sti swap into 1995 impreza (can bus + e throttle into obd1 + cable throttle car).
                          S54 has marginally more sensors than a S52:
                          3 knock vs 2 knock.
                          2 TPS sensors vs only 1
                          2 cam vs 1 cam sensor
                          double vanos has 4 wires instead of the single vanos 1
                          similar items between s52 and s54:
                          6x injectors both have.
                          6x coils both have. the wiring colour is even the same between s52 and s54 coil trigger wires!!!!!
                          temp sensor for air, water. oil pressure sensor.
                          4x o2 sensors both have.
                          IAC is actually direct interchange between S54 and S52. hilarious.
                          accessories are piece of cake. s54 will plug and play the alternator, power steering pump, AC compressor even of the S52. plug and play!!! I ended up bolting on a 328i cabrio 140 amp alternator as the S54 likes more power natively.
                          if one makes a hybrid harness it can get difficult to manage all going on, but honestly its not that hard if you know what you are doing.
                          Originally posted by Massimo
                          Is there any reason why an aftermarket management system like MSV3 would not work on this engine. Someone mentioned before that a standalone system would be $$$$, MS is not very expensive.
                          Personally if I had the money I would go standalone.
                          MS is not expensive if you don't cost your own time of building, setup, etc. If one is skilled at MS there is no reason it cannot run a S54b32.
                          I used a commercially avail. standalone on my own S54 swap last year because it was more Economical for what I wanted to do long term. I can wire in any ECU and re-map standalone/OEM dme's, but I cannot build a computer by myself.
                          Absolutely No way I would go through the expense/labor to install a S54 and not want to tune it more..............Alpha-N full tuning+ ITB S54 = sound of sheer maddness.
                          • Jean
                            • 18228
                            #103
                            S54 makes up for the ugly front end and wheels lol.
                            • e30 fa life
                              • Sep 2009
                              • 197
                              #104
                              thank you..............those are ROH wheels...................... all i could get for now to clear the brembo calipers!!!!!!!!!!!!!!!!!!!!!!!
                              • e30 fa life
                                • Sep 2009
                                • 197
                                #105
                                3 knock vs 2 knock.
                                thank you.............................you my friend make a lot of sense!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
