S54 Swap Question
  • E30Strube
    • Jul 2008
    • 181
    S54 Swap Question
    I'm not getting fuel and the engine isn't starting. It will turnover, but not crank. Since I have an E30 M3, I still have the 4 cyl module in the cluster. Would not changing it cause no rpm signal and no start?? The starter is seeing 12V as is the fuel pump relay. There is nothing at the inline pump.
  • jrdeamicis
    • Nov 2008
    • 956
    First..
    You can't ask a question like that and not tell us what is running it.
    Past Car : E30 S50 6 Speed 5 Lug 3.73
    Current : Z3 S50 OBD2 (Smog Legal) 6 Speed BBS RN Dual Ear Diff
    ___________________________________________
    BNB Designs
    Engine Swaps, Fabrication, Innovation, General Repair
    Richmond CA
    Julian 848-248-8029
    • VinniE30
      • 2113
      Zinno '89 <24v swap in progress>
      • E30Strube
        • Jul 2008
        • 181
        Sorry, should of included the info. Stock E46 M3 ECU that has been remapped, S54, into an E30 M3. I'm using the stock intank pump and a Walbro inline unit. Stock E46 M3 FPR.
        • FredK
          • 14762
          I haven't gotten this far yet... but in the key on position, are you getting power to pin 1 of the DME at x6004?
          I assume you're using a common single pole, single throw Bosch relay for the fuel pump? I'm assuming you aren't getting power at Terminal 87, otherwise the fuel pump would activate.
          The tach should not matter to the engine firing, at least it doesn't make sense that it would. The engine speed would, however, which is read off the crank position sensor.
            • 34844
            Are you running ews? Ews delete flash?
            The ecu doesnt care about the cluster coding.
            as far as the fp relay, don't you have to use the one from the e46 m3? its not just on/off, it varies pump speed based on load/rpm.
            More info on wiring and the tune are required.. Any chance you have access to diagnostics software?
            • 328ijunkie
              • May 2007
              • 3961
              Youre not gonna get away with running that fuel pump.
              Check Us out on Facebook
              Full Product Line Tuning
                • 34844
                E46 m3 fp is cheap and pretty much drops right into the in-tank pump carrier.
                • FredK
                  • 14762
                  Pretty sure he has the same flash I have, which deletes EWS as well as the need for a PWM fuel pump relay. Otherwise if you use a standard relay, it will rapidly click on and off, making a loud noise.
                  • e30s50dan
                    • Nov 2008
                    • 2076
                    A lot of info on s14.net engine swap section...but you may know that
                    NASA
                    BMWCCA member
                    PCA member 25yrs
                    1991 318IS slick top
                    1997 M3 sedan
                    2001 325CI DD
                    “whoever turns the wheel the least, wins"
                      • 34844
                      I dont know why you'd want to delete the relay? It should extend the life of the pump, keep the fuel cooler, not to mention being quieter. Is there some electrical complication preventing it's use in an e30?
                      I wouldn't want to drive 24\7 at 5 bar pressure. I wonder if they retuned the fuel for that? Maybe its an on/off multiplier variable?
                      • FredK
                        • 14762
                        I think it's been deleted. I don't think it's hard to use, but I'm not sure of what technical challenges it might present. I sourced a PWM relay "just-in-case".
                        • E30Strube
                          • Jul 2008
                          • 181
                          I'm just using a standard 12V 30A relay and as Fred said, the same reflash. We jumped the relay and the fuel pumps worked just fine. Fuel went through the lines as it is supposed to. I also verified it isn't getting spark. It would seem that the ECU isn't sending the signal to the relay to actually work. The same is true for the coils. Any ideas of what the ECU looks for in order for it to send the necessary signals for fuel and spark? I've read that the S52/50s look for the knock sensor, rpm signal, and cam position sensor.
                          • E30Strube
                            • Jul 2008
                            • 181
                            To the poster that said the pump wouldn't work...why is that?? The S14 stock inline pumps work at near 5 bar. The stock intank is just a low pressure pump that sends fuel to the inline. The walbro I'm using works up to 70 psi, which is more than enough to flow what is needed for the S54. It is also the same pump the guys at Horsepower Freaks uses for their setups.
                            • camberwears
                              • 167
                              hope you get it worked out Greg
                              sigpic www.camberwears.com Team16Niss-Meguiars-Underground Grafix -Mediagearbox
